Well I think I am almost finished with all the background work!
I have installed a couple of different themes so if you don't like the default one you can easily change it via your user control panel
I am going to change the smilies as I think they are shocking to be honest! probably go with the stock ones and add a few other basic ones to compliment them
I have figured out a way to make images work but it means manually editing the database and to do that for over 6k images is just suicide! So if its one of your posts missing images then feel free to edit the post and add the images back if you have them.
Avatars haven't transferred over either so feel free to upload a new one or delete the one thats supposed to be there
you may see a few new features available to you so feel free to try them out or ask questions about them
I am also open to suggestions and if I can accommodate I will do
Settling in.....
- Been liked: 207 times
Re: Settling in.....
Is it possible for me to change the information from the right back to the left(username, avertar etc)
Thanks.
Thanks.
- sakm
- Administrator
- Has liked: 469 times
- Been liked: 415 times
I know I like a challenge! I will see what I can do as normally this sort of thing would affect all accounts and require a lot of major changesburridge01 wrote: ↑Thu Aug 25, 2022 9:04 pm Is it possible for me to change the information from the right back to the left(username, avertar etc)
Thanks.
I do prefer profile on the left myself!
- Sharkfighter
- Been liked: 16 times
Sakm you've done a brilliant job, I'm getting used to the different layout and navigating my way around.
- sakm
- Administrator
ThanksSharkfighter wrote: ↑Fri Aug 26, 2022 7:49 pm Sakm you've done a brilliant job, I'm getting used to the different layout and navigating my way around.
I know things are a little different but they won't take too long to figure out where everything is
Thanks for taking on such a difficult task and doing it so well and with patience!
- sakm
- Administrator
Sortedburridge01 wrote: ↑Thu Aug 25, 2022 9:04 pm Is it possible for me to change the information from the right back to the left(username, avertar etc)
Thanks.
Go to user control panel click board preferences then go to Edit display options and look for Post profile side
This only has an affect on full screen mode and not when viewing on a mobile phone
