Author Topic: Starting issue  (Read 297 times)
Onlinepkpilot
  • Jr. Member
    Starting issue
    « on: 2019-01-09 13:17:47 »
    I am having an interesting starting issue.  My bike will not start if it is in gear even with the kickstand up.  It has to be in neutral.  I can start it in neutral with the kickstand down, then raise it and put the bike in gear.  Any ideas?
    P.K.
    Onlinebandytales
    • Sr. Member
      • Model/year: 2017
      Re: Starting issue
      « Reply #1 on: 2019-01-09 13:18:46 »
      What bike have you got?
      Onlinebandytales
      • Sr. Member
        • Model/year: 2017
        Re: Starting issue
        « Reply #2 on: 2019-01-09 13:23:26 »
        P.K.
        So If you pull the clutch lever in - with it in gear - will it start?
        Onlinemilleplod
        • Full Member
        • Country: england
          • Model/year: 1200RT/2006
          Re: Starting issue
          « Reply #3 on: 2019-01-09 20:10:23 »
          Sounds like the clutch microswitch playing up - it should start in gear, sidestand up, clutch pulled in. The switch sometimes fails, but more often than not its caked in road crap and just needs a good clean. A good squirt of contact cleaner into the switch might sort it, although the problem may return. I'd take the switch out and give it a really good clean-up. Be careful - there's a plastic pin that the switch pivots on, it looks like a small drawing pin (thumb tack) - it's very easy to lose it, and it's not available on its own, you'd need to buy a complete switch. My last switch-clean took all of 2 mins....then 45 mins rooting around in the pebbles on the drive to find the bloody pin!!  :eek:
          Pete
          Onlinepkpilot
          • Jr. Member
            Re: Starting issue
            « Reply #4 on: 2019-01-09 20:42:44 »
            Nope. Has to be in neutral. It will start in neutral with the clutch in or out.
            Onlinepkpilot
            • Jr. Member
              Re: Starting issue
              « Reply #5 on: 2019-01-09 20:43:57 »
              Pete
              Great idea.  Where exactly is that switch?  A photo would be appreciated!!
              Onlinemilleplod
              • Full Member
              • Country: england
                Re: Starting issue
                « Reply #6 on: 2019-01-09 20:49:55 »
