Author Topic: Mounting phone using GPS location  (Read 563 times)
OfflineAndy K
  • Newbie
  • Country: au
    • Model/year: 2014
    « on: 2019-03-21 11:56:02 »
    Hi All,
    I’ve got a 2014 r1200rt with the blanking plate over the GPS slot.  Im guessing to buy the gps OE will require me to take out a second mortgage and as my iPhone 10 can adequately sort me with directions, my feeling is mounting the phone is probably a better option - given I’ve just spent $900 (aus) on a Givi 56l monokey top box....
    The 2014 has no real handle bar real estate, and I can’t help thinking that the location specifically put there for the gps would be the most sensible option in location for the phone ( in a landscape orientation ).
    Has anyone worked out a way to either replace the blanking plate with some clever mount that holds a phone ?  Or maybe putting steel there somehow behind the blank and using magnets - or something else?  Any good problem solving engineers out there?
    Can’t seem to find anything that has used that area - so maybe it’s impossible - or is there a bracket that the oe option uses that can be used?
    Any ideas appreciated....
    Andy
    OnlineBeagle
    • Sr. Member
    • Country: gb
    • Every thing goes to Entropy - in this Age.
      • Model/year: R1200RT LE. 2018
      Re: Mounting phone using GPS location
      « Reply #1 on: 2019-03-21 14:25:38 »
      Hi All,
      Andy
      Can you not fix a phone mount to the face of the blanking plate.
      OnlineMikeS
      • Full Member
      • Country: gb
        • Model/year: R1250RT 2019
        « Reply #2 on: 2019-03-21 18:26:37 »
        What about looking for a second hand Nav V on eBay.  Seen them go for about  £300/350 over here. A more integrated, robust and waterproof solution. What what its worth you can use the twirly wheel on the handle bars to operate it as well.
        Mike
        OnlineBeagle
        • Sr. Member
        • Country: gb
          « Reply #3 on: 2019-03-21 20:27:51 »
          Hi All,
          Andy
          https://www.nippynormans.com/phone-mounts-and-cases?utm_medium=email&utm_campaign=How%20to%20navigate%20with%20your%20phone&utm_content=How%20to%20navigate%20with%20your%20phone+CID_f16ffc16c4286636672e8eefde194e65&utm_source=SelectMailer&utm_term=here
          OfflineAndy K
          • Newbie
          • Country: au
            • Model/year: 2014
            « Reply #4 on: 2019-03-23 00:29:53 »
            Mike
            Hi Mike,
            Unfortunately there isnt many on second hand out here in oz.. and I agree - having the thumb wheel connected for control  is a nice to have...  I’m guessing a uk one would need a different card (assuming you can access the card) - so it might be worth looking at.
            The ram option is also ther, using one of the star screw extensions on the fluid res - but I just figured putting the phone under the shield where there was a perfect place for it would make sense...
            Will see if I can cope till Christmas and the start dropping hints,,,problem is there’s a lot of shit needed now I’ve got this bike, inner bags, Bluetooth set, sat nav, new gear, better helmet, etc etc....
            Andy
            OnlineBoB21
            • Sr. Member
            • Country: gb
              • Model/year: R1200RT LE 2017
              « Reply #5 on: 2019-03-23 07:19:12 »
               you can put memory card in navs yourself and believe  purchase whatever maps you want to download. Worth looking into.
              Onlinetojjer
              • Jr. Member
              • Country: gb
                • Model/year: R1200RT LE / 2016
                « Reply #6 on: 2020-05-22 12:41:58 »
                Bit late for the OP, but if anyone is considering the same:
                https://images.app.goo.gl/2i3hShwFWtyzfXvm6
                Offlineexportman
                • Full Member
                • Country: england
                  • Model/year: R1200RT LC 2016
                  « Reply #7 on: 2020-05-22 15:06:47 »
                  Onlinebeemerboy9
                  • Sr. Member
                  • Country: gb
                    « Reply #8 on: 2020-05-22 22:16:58 »
                    Wunderlinq allows to control of the iphone from the Wonderwheel.
