Author Topic: 2008 RTP ABS - Fiesta pump replacement  (Read 196 times)
OfflinePlodbike1962
  • Newbie
    • Model/year: R1200 ZRTP 2008
    « on: 2019-04-15 13:25:15 »
    I run a R1200RTP. The brake failure light is on and I've had the system check at a dealer Coopers in Tunbridge Wells Kent. So the unit is faulty and needs attention. [/font][/size]I have read that you can replace the unit with a Ford Fiesta unit. I have now aquired a pump using the number given off another website. However the unit has two extra pipe holes obvs for 4 wheels. Can you advise which holes I should blank off and the ones I should use ? Thanks
    Onlinemilleplod
    • Full Member
    • Country: england
      • Model/year: 1200RT/2006
      Re: 2008 RTP ABS - Fiesta pump replacement
      « Reply #1 on: 2019-04-15 16:37:03 »
      Is it the motor that's u/s? If so, I think the accepted fix is to simply swap the motor over from the Fiesta unit, as they're identical. Did you do a search over on UKGSer - I assume it's you that's asked the same question over there?
      Pete
      OfflinePlodbike1962
      • Newbie
        « Reply #2 on: 2019-04-16 15:47:32 »
        Hi Yes I did and it was where I got the info from, pump number etc. But as you say I think its a case of swaping the motor now. Unless anyone knows better. Pleas let me know.
        Onlinemilleplod
        • Full Member
        • Country: england
          « Reply #3 on: 2019-04-20 16:32:11 »
          You might have already spotted it, but DrFarkoff (Jay) over on UKGSer has replied saying it's just the motor that is used - his business is BMWs, so he knows his stuff!
          Pete
