Author Topic: Heed rear crash bars  (Read 425 times)
OfflineMalcvtr
  • Newbie
  • Country: gb
    • Model/year: R1250RT 2019
    « on: 2020-05-21 10:07:55 »
    These were fitted to my R1250RT, but I’m pretty sure they’d fit the R1200RT LC too because the whole of the footrest bracket/frame area looks identical to the R1250RT.
    Anyway, these have been on for about 300 miles (simply because I’ve hardly ridden the bike). I’ve decided to take them off as I’m not riding much at all and they look a bit big if you ride without the panniers as I do most of the time.
    Anyway, they’re £137 posted via eBay. They are gloss black. They fit very well - the holes all line up! Everything is there, including the original instructions.
    Stupidly, I took them off before photographing them, so there is a picture attached from eBay.
    £90 posted.
    https://uploads.tapatalk-cdn.com/20200521/b37ecd662a81a68780756a1bdfd83650.jpg
    https://uploads.tapatalk-cdn.com/20200521/d892bbb0893e806e2c97c3bb8b8bdace.jpg
    https://uploads.tapatalk-cdn.com/20200521/41d1c776fe83a1e1eebc79607f79ad09.jpg
    Offlinehammo
    • Full Member
    • Country: gb
      • Model/year: 2018 RTLE
      Re: Heed rear crash bars
      « Reply #1 on: 2020-05-21 17:37:45 »
      Do not know if you received my message , if they fit a 2018 RTLE i,m definately interested cheers Hammo.
      OfflineMalcvtr
      • Newbie
      • Country: gb
        « Reply #2 on: 2020-05-21 20:29:24 »
        Yes I did, thanks, and I've replied. Apologies for the delay - DIY jobs kept me busy
        OfflineMalcvtr
        • Newbie
        • Country: gb
          « Reply #3 on: 2020-05-21 20:44:10 »
          I don't know if they'll reply, but in addition to the approach I suggested in my message, I've emailed Heed and asked the question
          Offlinehammo
          • Full Member
          • Country: gb
            « Reply #4 on: 2020-05-22 08:33:09 »
            Ok i will await for you to confirm many thanks Hammo
            OfflineMalcvtr
            • Newbie
            • Country: gb
              « Reply #5 on: 2020-05-22 12:44:56 »
              Just to add to my belief that these bars will fit the R1200RT LC from 2014, the Wunderlich site states that their rear bars, "Fits all model years of the R1200/1250 RT LC".
              Since the Wunderlich bars fit entirely to the rear footrest brackets, these brackets must be identical, as I suspected.
              The Heed bars fit to these same brackets and one other mounting point - the end of the subframe rail that the footrests attach to. I can tell you that the distance between the centre of the lower of the two footrest bracket mounting bolts and the centre of the subframe end bolt is just over 12cm - about 12.2.https://uploads.tapatalk-cdn.com/20200522/bac136a9158db8a741887bb558f021ed.jpg
              https://uploads.tapatalk-cdn.com/20200522/f5d23711c9ba9c1fa8c0668fccbd519f.jpg
              OfflineMalcvtr
              • Newbie
              • Country: gb
                « Reply #6 on: 2020-05-22 17:00:32 »
                Now sold. Thanks.
                OfflineOld-Git
                • Full Member
                • Country: gb
                  • Model/year: R1200RT LE 2015
                  « Reply #7 on: 2020-05-23 10:19:27 »
                  Now sold. Thanks.
                  Bah. I would have had these. Ah well, question for you please - like you I ride with just the top box most of the time, but panniers will go on for longer rides / tours, how long does it take to fit / remove these bars?Thanks Nick
                  « Last Edit: 2020-05-23 10:36:13 by Old-Git »
                  OnlineCasbar
                  • Hero Member
                  • Country: gb
                    « Reply #8 on: 2020-05-23 15:05:10 »
                    I now do the same, I fitted Illium rear bars, they take all of 5 mins to fit and remove. There is a UK distributor as well, sport touring in Wales.
                    OfflineMalcvtr
                    • Newbie
                    • Country: gb
                      « Reply #9 on: 2020-05-23 20:38:34 »
                      Hi Nick. Well, they're not quick, but I'd say you could do it in thirty minutes once you'd done it a couple of times.
                      The only awkwardness is where the BMW designers, in their wisdom, decided to have part of the bodywork under the seat swoop over and partially cover the upper of the two footrest bracket mounting bolts... But there is a simple workaround. There is a bolt securing part of the underside of the bodywork a few centimetres further along towards the rear of the bike. Remove this and you can gently bend the bodywork up and get access to the footrest bracket bolt.  I used three layers of electrical insulation tape on the bodywork at that point to make sure I didn't mar the paintwork. I've done it twice now and there's not a mark on the paint.
                      I would say that the Heed bars are well made and, unlike the Wunderlich engine bars I have, all the holes lined up perfectly.
                      Hope that helps.
                      You can see the offending area of bodywork in this pic:
                      https://uploads.tapatalk-cdn.com/20200523/7f9093b9d86325b33a724cbcd92e4928.jpg
                      « Last Edit: 2020-05-23 21:34:07 by Malcvtr »
                      OfflineMalcvtr
                      • Newbie
                      • Country: gb
                        « Reply #10 on: 2020-05-23 20:40:02 »
                        The Illiums are great but fiendishly expensive - I think they're well over £400 in the UK, aren't they?
                        Just checked - £429.99. That's a lot of dosh for the saving of time in my opinion. Nearly £300 more expensive...
                        « Last Edit: 2020-05-23 20:48:59 by Malcvtr »
                        OfflineMalcvtr
                        • Newbie
                        • Country: gb
                          « Reply #11 on: 2020-05-24 09:19:33 »
                          Hammo, I've sent you a message. Thanks.
                          OfflineOld-Git
                          • Full Member
                          • Country: gb
                            « Reply #12 on: 2020-05-24 09:30:01 »
                            Thanks Malcvtr and Casbar. The Ilium bars are lovely, but not £300 lovelier than the Heed, which is what I will be buying.
                            OfflineMalcvtr
                            • Newbie
                            • Country: gb
                              « Reply #13 on: 2020-05-24 16:58:21 »
                              Hi Nick. Just in case it helps, the procedure I described for getting access to the upper footrest bracket bolt is shown in this video for the Ilium bars:
                              https://youtu.be/822XYJU0kjQ
                              OfflineOld-Git
                              • Full Member
                              • Country: gb
                                « Reply #14 on: 2020-05-24 23:11:50 »
                                it does, many thanks.
