Author Topic: Throttle Gizmo  (Read 259 times)
rtaus and 1 Guest are viewing this topic.
OfflineDaveCly
  • Full Member
  • Country: england
    Re: Throttle Gizmo
    « Reply #15 on: 2020-08-02 13:32:16 »
    I tend to get it in summer during a long ride. are when touring, I put it down to the thin summer gloves I wear, definitely not as bad with a thicker glove ... only happens to the right hand (awaits silly comments ☝️)
    OnlineBeagle
    • Sr. Member
    • Country: gb
    • Every thing goes to Entropy - in this Age.
      • Model/year: R1200RT LE. 2018
      Re: Throttle Gizmo
      « Reply #16 on: 2020-08-02 14:25:00 »
      I am convinced it is prolonged gripping the throttle with gloves on that reduces blood flow to the fingers. Usually after an hour or so.
      Thanks guys for the sensible replies.
      OnlineDavid.
      • Hero Member
      • Country: gb
        • Model/year: R 1200 RT / 2012 (Camhead)
        Re: Throttle Gizmo
        « Reply #17 on: 2020-08-02 15:30:40 »
        I like the small in circumference grips, get better feedback from the bars rather than increasing the diameter with additional coverings designed to reduce vibration and feel.
        (I haven't got spades for hands).
        Same as riding with thicker style winter gloves on, just wear summer gloves and turn up the heated grips.
        Relaxing the grip on the throttle will obviously help.
        Also use the cruise control through villages etc. when out on country roads to maintain the signed speed limits, gives my hand a break.
        « Last Edit: 2020-08-02 15:47:45 by David. »
        OfflineDaveCly
        • Full Member
        • Country: england
          Re: Throttle Gizmo
          « Reply #18 on: 2020-08-02 16:20:03 »
          Not recommended in 32c Spanish heat David 😂
