New Link collection manager added
Seeing what should be the silver backdrop of the glass, which is what usually enables you to see the oil level (brown against silver).
In fact the window is cloudy, a brownish color.
Which means that when you drain the oil, the oil cooler retains its capacity as the thermostat remains closed.
Thermostat will only control flow to the cooler, not from it.
Cold thick gloopy oil will stick to everything, every crevice especially with horizontal cylinders - if there is no oil pressure moving it on then it will lurk all around the motor including the cooler. Warm thinned oil is much more compliant with gravity. The LC method is the same.I would also suggest the volume of oil in the cooler is actually pretty small, but in any case it doesn't sound very German to start a cold engine with a quantity of oil 'locked' away from the coal face until the engine heats up. Start a cold engine and shut it down, the oil pan will look empty for a few hours maybe even a day but eventually it will fill back up.
