Please set your country in your "Forum Profile" !
The point i am making is that the oil cooler and the rest of the engine will empty if its cold or hot, just at a different rate, whether that is relevant or useful is up to whomever, but it is factual nonetheless. The notion that oil is locked away somehow, isn't.The horizontal part is very important forgive the analogy but if you take the lid off a tin of room temperature treacle and lay it down on its side (or horizontally, or even upside down) it will take a long time to empty but if you heat it up and repeat it will empty a lot quicker. The procedure is the same for an LC model which doesn't have a cooler, which also implies that heating up is not really connected to the cooler.
Does the sight glass look like this one.Re: “NEW” 2011 RT, question on oil level sight window
What is the reason for the appearance of the first sight glass?
The bike is super clean and only had 4,600 miles on it. I’m the 3rd owner, the first put about 3,200 miles on it, and the guy I bought it from had it for 8 years and only put about 1,400 miles on it. The Florida dealer said the last time they say the bike was for an oil change in 2017.
Can anyone guess why and what I can do to fix it?
I read somewhere a procedure for my 2012 bike. Put the bike on the side stand for 10 minutes after it is used (warm) so the oil cooler can drain, then use the centre stand wait again 10 minutes. Now the oil cooler is as empty as possible and the oil level is at it’s maximum.
Will be interesting to check it again in the morning.
