Author Topic: Diagnostic program to download  (Read 278 times)
B787MECH and 2 Guests are viewing this topic.
OfflinePeteJLbeemer
  • Newbie
    • Model/year: R1200rt 2005
    « on: 2021-05-01 20:16:21 »
    Hi,  Does anyone know if there is anything I can download onto my laptop to run a diagnostic check on my 1200rt 2005 model.  I know most would say to buy a dedicated diagnostic machine/computer but I've managed to download something in the past for my Triumph.
    Thanks
    OnlineDavid.
    • Hero Member
    • Country: gb
      • Model/year: R 1200 RT / 2012 (Camhead)
      Re: Diagnostic program to download
      « Reply #1 on: 2021-05-02 10:10:46 »
      Plug-in diagnostic equipment is beyond my technical ability, I get a man in. However, when doing a "Google" search, something called Motoscan seems to pop up regularly. I've no idea whether or not there is an alternative to the GS911 diagnostic tool. From what I've read elsewhere, it's seems BMW like to keep things unique in order to make it difficult/expensive for DIY diagnostics. I know someone who also has a Triumph and is able to do his own plug-in diagnostics.
      OfflinePeteJLbeemer
      • Newbie
        « Reply #2 on: 2021-05-02 11:53:21 »
        Hi David,
        Thanks for the reply, will have a look at this motoscan you mention,  doesn't surprise me if that's true about BMW making it difficult for anyone to run an alternative diagnostic test other than their own.
        Thanks
        Offlinebeemerboy9
        • Hero Member
        • Country: gb
          • Model/year: R1250RT 2019
          « Reply #3 on: 2021-05-02 12:26:26 »
          Thanks
          If it is anything to with the ESA, you may be due a number of Chassis Control Module updates. When I had my 2005 model updated in early 2014 there were 6 or 7 updates applied by the dealer, one of which brought the ESA back to life until I sold it.
          Onlineexportman
          • Full Member
          • Country: england
            • Model/year: R1200RT LC 2016
            « Reply #4 on: 2021-05-02 15:13:16 »
            I use motorscan with my 2017 RT it works fine but you need to have a compatible device to export the data from the bike. I am not sure what year BM started putting OBDII ports on their bikes it may not work with the BMW proprietary port.
            (Triumph were an early convert to OBDII)
            Check the motorscan website and support pages
            Offlinerangemaster728
            • Jr. Member
            • Country: us
              • Model/year: 2009 R1200RT
              « Reply #5 on: 2021-05-16 16:02:06 »
              IF you have (or can acquire a cheap) Android device then look into MotoScan. It has several levels of capability, the top level being MotoScan Ultimate for about $50USD.
              https://play.google.com/store/apps/details?id=de.wgsoft.motoscan&hl=en_US&gl=US
              It also requires a Bluetooth OBD reader (I recommend the OBDLink LX, about $60USD):
              OBDLink LX OBD2 Bluetooth Scanner for Android and Windows
              by ScanTool
              Learn more: https://www.amazon.com/dp/B00H9S71LW/ref=cm_sw_em_r_mt_dp_CRJ6F62HDEW0T6WMRS4D?_encoding=UTF8&psc=1
              and an adapter cable to go from the BT reader to the BMW round diagnostics connector ($18USD)
               Qiilu OBD2 Diagnostic Cable for ICOM D Module Cable 10pin OBD Adapter for , Motorcycles Diagnostic Cable Tools Work with ICOM or ICOM A2 A3
              by Qiilu
              Learn more: https://www.amazon.com/dp/B075K7MQFC/ref=cm_sw_em_r_mt_dp_0QWH2G69FKCGFE25EXF0?_encoding=UTF8&psc=1
              So this setup cost me $130USD as I already had an old Android phone laying around (MotoScan does not have an iOS version for Apple devices)...it does many functions, has good tech support and for most riders will do everything you want to do in the much more expensive GS-911 platform.
              I have BOTH the GS-911 and a MotoScan setup and use MotoScan 90% of the time when working on Hexhead bikes.
              Check it out...
              OfflineRT Mike
              • Newbie
              • Country: us
                • Model/year: 2016 BMW R1200RT
                « Reply #6 on:Yesterday at 03:50 »
                Will the MX work with BMW motorcycles?
                No matter how thinly something is sliced, there is always two sides.
