Author Topic: Shift up indicator  (Read 175 times)
Offlinepaulgelineau
  • Newbie
  • Country: us
  • 2015 R1200RT & 2014 F800GT
    Shift up indicator
    « on: 2021-07-21 16:44:19 »
    My 2015 1200RT has the "shift up" indicator and I'm curious what that is predicated on.  Speed, torque, RPM or a combination of all?  I don't generally use it to tell me when to shift as after 30+ years of riding I can tell when to shift up or down.  Just a curiosity question.
    Cheers,
    Paul G.
    Onlineexportman
    • Full Member
    • Country: england
      • Model/year: R1200RT LC 2016
      Re: Shift up indicator
      « Reply #1 on: 2021-07-21 18:37:02 »
      Seems to be on RPM,  guess it about meeting the emissions regulations.
      OnlineGavj
      • Jr. Member
      • Country: scotland
        • Model/year: R1250RT 2020
        « Reply #2 on: 2021-07-21 18:37:34 »
        On my 2020 it appears to be for economy, not sure of the parameters used but similar to my wife's car. If your light on the throttle it suggests shifting up. I switched mine off, found it distracting having an orange light / symbol appearing on the dash...... as with you, I know when to shift
        OnlinePeter Baker
        • Full Member
        • Country: gb
          « Reply #3 on: 2021-07-22 07:11:42 »
          As above, pretty sure it is "economy focused" to help you get better mileage...  Peter
          OnlineCasbar
          • Hero Member
          • Country: gb
            • Model/year: R1250RT 2019
            « Reply #4 on: 2021-07-22 09:23:54 »
            On the KTM 1290, you can adjust it yourself, obviously it won't let you go higher than the max rpm.
            OnlinePeteM
            • Sr. Member
            • Country: gb
              « Reply #5 on: 2021-07-22 10:01:44 »
              Mine is definitely economy/emissions based. I've turned it off as I find it annoying
              Offlinesakm
              • Newbie
              • Country: gb
                • Zumo User Forums
              • Model/year: 2016 R1200RT
              « Reply #6 on: 2021-07-22 10:50:28 »
              They work in a strange way!
              steadily cruising along it will tell you to go in as high a gear as possible
              Giving it some stick it will tell you to hold the gears longer
              I turned mine off as I found myself following its advise and the bike just felt like it was in the wrong gear all the time
