Author Topic: Pannier protection from BMW  (Read 397 times)
OfflineSteve398
  • Jr. Member
  • Country: gb
  • Retired Black Rat
    • Model/year: BMW R1200RT LE, 2018
    « on: 2021-10-08 20:07:35 »
    Hi
    In a rash moment I ordered the rubber/plastic and hideously expensive pannier protection guards.
    £155 later I have 4 bits of plastic with some thin allegedly sticky bits to press in non-indicated positions against the pannier… no cleaning wipes, no instructions.
    I appreciate it’s probably meant to be self evident but with these things you get one chance, try and remove to replace them elsewhere and the damn things will undoubtedly fall off.
    Impressed? No… just a warning really, don’t bother.
    OfflineT6pilot
    • Hero Member
    • Country: us
      • Model/year: 15RT
      Re: Pannier protection from BMW
      « Reply #1 on: 2021-10-08 20:27:29 »
      I’ve used the BMW skid protection on both my 1600gt and 1200rt, I can honestly say they work, I’ve had in my weaker moments a couple zero speed tipovers with only a little scratching on the protectors and obviously protected the paint
      Takes a little planning on their install before you pull the tape off, some swabs dipped in alcohol to clean the surface and your good to go
      One tip, remove and lay panniers on their side
      Offline60Aviator
      • Newbie
      • Country: us
        • Model/year: R1250RT/2021
        « Reply #2 on: 2021-10-09 02:10:28 »
        They should have come with a template as mine did. Here are the instructions maybe dealer can print a new template.
        « Last Edit: 2021-10-09 02:18:55 by 60Aviator »
        “I’d rather go down the river with seven studs than with a hundred shitheads” Charlie Beckwith
        OfflineSteve398
        • Jr. Member
        • Country: gb
        • Retired Black Rat
          « Reply #3 on: 2021-10-09 14:24:38 »
          Invaluable, thanks for the replies. 👍
