If anyone's interested here is a record of my valve clearances on my 2013.
Mileage 8554 10072 11888 15868
R/H side Ex Upper .38 .38 .39 .39
R/H Side Ex Lower .36 .35 .36 .36
R/H Side in Upper .18 .19 .19 .19
R/H Side In Lower .18 .17 .15 .15
L/H Side Ex Upper .36 .35 .35 .35
L/H Side Ex Lower .38 .34 .34 .34
L/H Side In Upper .18 .17 .16 .16
L/H Side In Lower .16 .16 .15 .15
Valve measurement records
- Been liked: 335 times
Re: Valve measurement records
Excellent, all within spec. of, Inlet 0.13 to 0.23mm & Exhaust 0.30 to 0.40mm.
My 2010 RT covered over 36,000 miles & only ever had the Valve Clearances checked, non required adjusting.
On enquiring with a local Dealer, the Parts Dept. told me they had never ordered any replacement shims for a TC RT.
Checked the clearances on my 2012 RT for the first time at 6,680 miles, all were with the specs.
great to see that adjustment doesn't need to be changed much at all on the 2010+ models. anyone else have more info on their bikes that they would like to add? I've only had mine a couple weeks so there isn't a lot for me to contribute till i get done going through the previous owners records.
This thread about 2010 DOHC Valve Adjustment, https://www.1200rt.com/index.php/topic,1079.0.html might be of interest.arkmark wrote:Anyone have more info on their bikes that they would like to add?
