Right stowage compartment - 2014RT
- Bike Model and Year: RT 2018 LC
Does anyone know if there is a drain hole in either of the pockets? Everytime there is heavy rain the right pocket fills with water and the left to a small degree. Any thoughts greatly appreciated as to how to stop this.
Re: Right stowage compartment - 2014RT
I can't advise on drain holes on the pockets, but what always surprises me is how much water the mirror cowlings collect, especially after washing the bike. Not a major issue, just a bit surprised at the design.
Don't know about any drain holes but I've never had any water ingress to either front pocket.
Could be that it's not closing properly?
- Spencert231
Whenever I ride and get caught out in the rain or after washing the bike I give it a blast with my Airforce Master Blaster it an hot air blow for those not familiar with it, but does a great job of drying the bike.
jjwill wrote: Does anyone know if there is a drain hole in either of the pockets? Everytime there is heavy rain the right pocket fills with water and the left to a small degree. Any thoughts greatly appreciated as to how to stop this.
Mine don't leak. Not sure it's a helpful suggestion but I'd be more inclined to try and solve the leak, rather than start drilling holes...
My 2012 RT compartment DOES definitely have a pre-drilled rain hole. I think it would be crackers to design them without as there is always the risk some clutz doesnt close the lid properly and rain gets in, so be surprised if the 2014 didnt have it.
- Spencert231
Yes, but unless you've won the lottery I wouldn't both the expense is extraordinary.Benchmark wrote: Question, can the right pocket be retrofitted to the 2015 ?
Drain hole would be easy to do, make sure of what's below it before drilling away
My 15 does not have a drain hole, I would suspect you have a issue with the raised rubber seal that surrounds the inner lip of case, if bike is still under warranty a trip to dealer may be in order. My first step would be to remove seal and give it a good inspection also take a close look at lid and insure it closing all the way with no obstructions. And no my 15 doesn't leak
