Garmin Express - New Map Update
Been liked: 480 times
Re: Garmin Express - New Map Update
A little bit more research has revealed that there are 2 Map versions, NT & NTU.
It sounds like NTU is the latest version & are updated up to 4 times per year, whereas, NT are only updated twice per year.
My Garmin Zumo 660 was purchased in March 2011, this change may have taken place since 2010.
If you have a look at the loaded maps in your 660 it will show if its got NT or NTU.  The software connected to this latest update seems to have changed the format of some apps like the saved routes as its showing the dates they were last used.  There's also an app by date that pulls up your journey. Can't remember that being there before.
My 660 does indeed have NT Maps installed.
A phone call to Garmin Customer Services has confirmed the above differences in Updates between NT & NTU Devices.
Garmin Express has just flagged up that an Update to 2016.20 Maps is now available for my Device.
smileymiley
Has liked: 6 times
Been liked: 11 times
Post by smileymiley »
DaygloDavid wrote: Garmin Express has just flagged up that an Update to 2016.20 Maps is now available for my Device.
Yep, loaded mine up today too!
Formatted my SD Card, Updating Maps in progress, Estimated Time Remaining: 5 hours, fingers crossed, could be a late night.
Mine started out telling me 5 but it took 8 including the software update
Maz12
Post by Maz12 »
Is it necessary to format the SD card first?  I did the firmware update  last week sometime and the map update earlier this week,  but just plugged it in and downloaded to computer and device
As I haven't used the satnav since am I likely to have issues by not formatting the card  prior to updating?
guest3074
Post by guest3074 »
Maz12 wrote: Is it necessary to format the SD card first?  I did the firmware update  last week sometime and the map update earlier this week,  but just plugged it in and downloaded to computer and device
I put the card in my Nav V (straight out of the packet) before I updated and because it saw the extra space it placed the updated maps on the SD card  :)
Maz12 wrote:Is it necessary to format the SD card first?
What size SD Card do you have in your Device, I only have a 4 GB SD Card installed in my Device.
Before starting the Map Update, Garmin Express said, "a Memory Card is needed as all the information will not fit on the Device's internal memory".
My understanding is that Formatting the SD Card clears it & gives sufficient Memory for the Map Update.
Maz12
Post by Maz12 »
I think it's a 16gb card?  I wonder if it put the map on the card or device or both
guest3074
Post by guest3074 »
Maz12 wrote: I think it's a 16gb card?  I wonder if it put the map on the card or device or both
Garmin Express should decide that for you and offer to install on the card as the update is too big for the device.  ;)
Maz12
Post by Maz12 »
I didn't have to tick any boxes except when choosing to install to device And computer
Job done in around 4 hours, Device & PC (BaseCamp & MapSource) all now Updated with 2016.20 Maps.
Maz12
Post by Maz12 »
I checked to see what maps are on my device.. Europe DEM
        CN Europe NTU
        2016.20 3D
        CN Europe NTU
        2016.20 ALL
Removed SD card (32gb) and checked what maps remained..  All of the above, so I seems Garmin express put the updates on my device and not my SD card
