Route transfer to 660
Re: Route transfer to 660
I suspect Mapsource is accepting the map updates but there has been no software updates to it since 2010.
- Been liked: 332 times
Created a route in MapSource using 2016.10 maps, transferred directly to 660, (didn't ask to re-calculate).
Previewed the route on the Device, the Distance, Time & Shape of the route look spot on, as per MapSource.
This confirms to me that the version of MapSource on my PC works perfectly with my 660.
The "Find Places" option on MS is more user friendly than on BC.
Recently created a route in Basecamp using 2016.10 Maps for the Centre of GB Trip.
Since then, have updated my Garmin Zumo 660 & PC to 2016.20 Maps.
Also successfully transferred the route which was created in BaseCamp to MapSource.
Both BC & MS routes have been emailed to others who have been able to open them up.
Thought I'd have a go at transferring the routes from both BC & MS to my 660.
In both cases, the 660 wanted to recalculate the routes, this is normal as the routes were created in 2016.10, before 2016.20 updates were applied.
When previewing the 4 routes on the 660, in all cases, the distance, time taken & shape of the routes look the same.
Has anyone else who's got the routes had a go at transferring them to their GPS Unit.
- k9doc
- Has liked: 2 times
- Been liked: 9 times
Been using Mapsource and Zumo 660 for years with no problems. The Mapsource system only manipulates the Map Data so doesn't need updating if it's working ok.
When constructing the route in Mapsource there are options as to which format to save the file in. Choose .gdb and send to the Zumo as normal. There should not be any recalculating.
If it's a route created on a previous map version then what I do is as follows;
- copy the route over to a new file
- recalculate said route (now in the updated map version) and add a full stop to the name to make it a little different to the old one, also give it a different colour
- paste the original back in and then compare the two to check for any recalculation
- adjust as necessary, delete the original and download the updated route
- providing all versions of map data are the same, then no recalc will take place
I recently bought a little laptop to take on biking trips and successfully downloaded Mapsource (you have to download basecamp first for some reason) and the only issue was that it didn't show the world map (no loss) but did successfully import 2016.2.
All working fine.
You can then proceed to delete Basecamp should you so desire.
It's ok to be a dinosaur.
All working fine.
Chris
Chris, please may I ask if you've had a go at transferring either or both the MapSource/BaseCamp Centre of GB Routes to your 660, thanks David.
- k9doc
@David. The first file arrived from you as a .gpx and the second .gdb. I transferred both (having renamed one) to my Routes folder from 'Downloads' and they both opened in Mapsource as .gdb with no issues. I was expecting the .gpx file to open as straight lines and then have to recalculate but that wasn't the case.
I have noticed that for ages now there is very little, if any, recalculation when 'refreshing' (see earlier post) a route compiled on an earlier map version. Maybe that will be different on the continent where they actually do build new roads.
Chris
- k9doc
@David. Sorry, didn't read your post properly. I have just downloaded both routes independently into my 660 with no issues and both opened ok.
I presume you're on 2016.2.
Chris
The first file (.gpx) was created in BaseCamp, I had a go at transferring the route to MapSource (.gdb), your preferred option, then sent a second email.k9doc wrote:The first file arrived from you as a .gpx and the second .gdb.
Great stuff, that's 2 of us who know where we are going.k9doc wrote:I have just downloaded both routes independently into my 660 with no issues and both opened ok.
Yes, I'm on the latest 2016.20 Maps for both MapSource & BaseCamp , plus my 660.
