Found a puddle of oil below a cylinder, on investigating the cam chain tensioner bolt had slackened allowing a drip of oil to run down onto the header. Had to remove the throttle body to get access to tighten said bolt.
After doing a bit of homework on this it seems to be a common problem with these motors.
Anyone else had this experience?
Cam chain tensioner oil leak.
Re: Cam chain tensioner oil leak.
Not a common problem I think. Done up properly it shouldn't happen again.
Hopefully not, there is a fair bit of info on it online.
When i read about the perils of drinking i gave up reading.
- Been liked: 335 times
Not had any problems with either my 2010 or 2012 TC's.
Found this thread on BMWMOA, http://forums.bmwmoa.org/showthread.php ... k-6K-miles, might be worth saving for future reference.
When you read Davids above link, through, you see that the problem was eventually traced and resolved, so as said worth noting for future reference. ( good `find' , David ).........
That was my experience with mine and solved the same way.
