high beams
Re: high beams
Personally I find it irritating and unnecessary speaking from a car driver and a biker
Re: high beams
+1Gman1969 wrote: Personally I find it irritating and unnecessary speaking from a car driver and a biker
And here in the UK although not specifically illegal, you could get points for driving without due care and consideration,
Re: high beams
On this side of the pond, most ride with their brights on in daylight has we have so many distracted drivers, their is a term triangle of visibility, brights and Photon Blasters create this. At night low beams
I've often thought if a locomotive headlamp could be installed I would be the first
- 7vwh
- Has liked: 18 times
- Been liked: 40 times
Re: high beams
There is a specific offence of causing unnecessary dazzle, £50, no points!Benchmark wrote: +1
- Has liked: 14 times
- Been liked: 7 times
Re: high beams
+1 its just unnecessary in my view, PeterGman1969 wrote: Personally I find it irritating and unnecessary speaking from a car driver and a biker
Re: high beams
It's just inconsiderate, bordering on rude. No need to do it especially with the very effective LED running lights.
- Been liked: 480 times
Re: high beams
Does the same apply to using front or rear fog lights in normal visibility (day or night) conditions.7vwh wrote:There is a specific offence of causing unnecessary dazzle, £50, no points!
Re: high beams
Yes specific offences for both front and rear foglights, only to be used in reduced visibility day or night.
Re: high beams
Just a shame due to cut backs that traffic dept's have shrunk over the years step2534 wrote: Yes specific offences for both front and rear foglights, only to be used in reduced visibility day or night.
- 7vwh
Re: high beams
It's harder to prove the dazzle element during daylight, especially on a sunny day, night time is a different matter, especially in the wet!DaygloDavid wrote: Does the same apply to using front or rear fog lights in normal visibility (day or night) conditions.
Re: high beams
I think it is very inconsiderate to use high beams in the daytime and dazzle oncoming drivers/riders, I flash my lights several times and then leave them on full beam if oncoming vehicles do it to me. It's a shame the police don't enforce the rules of the road a bit more.
Re: high beams
the cars are now equipped with auto dip headlights hopefully the bikes will be the same soon that should stop the tossers from dazzling you when they are coming towards you :wonder:
Re: high beams
Hope they can come up with a auto-switch off for front and rear fog lights when the visability is over 100mfutterweasel wrote: the cars are now equipped with auto dip headlights hopefully the bikes will be the same soon that should stop the tossers from dazzling you when they are coming towards you :wonder:
People seem to use their front fogs all the time, regardless of weather conditions
Re: high beams
I ride with the low beams and the LED fog lamps on at all times. This gives a good triangle. The K1600 has Clearwaters set at 50% as not to blind someone the RTP has BMW LEDs.
