adding seat padding
turdboman
adding seat padding
Post by turdboman »
Hi,has anyone got any genius ideas to soften the low seat for long trips ?
T6pilot
Re: adding seat padding
Post by T6pilot »
Airhawk gel pad
Lots of positive feedback
richardbd
Post by richardbd »
T6pilot wrote: Airhawk gel pad
especially if you like sitting high in the air!
DaveCly
Has liked: 80 times
Been liked: 53 times
Post by DaveCly »
turdboman wrote: Hi,has anyone got any genius ideas to soften the low seat for long trips ?
Not on the RT seat, but I've done a couple of other bikes, carefully take the cover off the seat and cut a 1" piece of memory foam to the shape of the top of the original pad, I didn't even glue it, and refit the cover 👍
step2534
Post by step2534 »
Thicker underpants  easier and cheaper  :be happy:
richardbd
Post by richardbd »
step2534 wrote: Thicker underpants  easier and cheaper be
or more pies...
Nobby
Post by Nobby »
It's often a problem - the lower seat is lower because padding has been removed ... which makes the seat less comfortable for longer trips!
If the bike is a long term purchase, it might be worth considering having the suspension lowered, and keeping the the original seat.  Lots of people do it on other bikes, but I haven't heard of it on a BMW.  I also have a Triumph Rocket and there are loads of people on forums who've had the suspension lowered.  Might be worth exploring?
step2534
Post by step2534 »
Joking aside, I took my original seat and had 25mm shaved off the foam and it made a lot of difference, it is more comfortable than the low one and I kept the heater element.
What I should have done as well if at all possible was to have the seat width shaved off a little. I do find  it a little (not much) too wide.
Ive had a few seats sorted by Tony Archer at Huddersfield I might see what can be done later this year
My legs seem to be splayed quite a lot when I have to put both feet down
I owned a R1150rt and the seat on that was even wider but I found it very comfortable. I am 29 to 30 inside leg
