Chaps,
My near-side pannier won't attach. The handle simply won't click down into place.
I suspect something isn't happening when I locate the pannier on the mount - the lock isn't engaging or something.
Any ideas?
2014 LC - central locking.
Pannier won't attach - HELP!
- Has liked: 30 times
- Been liked: 29 times
Re: Pannier won't attach - HELP!
Take it off the bike.
When you try and press the handle down, is the foot on the back of the case, locking up in position?
If it's not moving, or feels 'springy', I suspect the fault is inside the case. Of you're not sure, compare it to the other pannier,
You can have a look inside to see what's happening. It's not as bad as you think. Remove half of the hinge, and then remove all of the screws on the bottom half of the case. This will allow you to remove the plastic liner.
When this happened to me, the bottom clip inside had jumped out of position. I was able to refit it, and it's been fine ever since.
Shouldn't it be covered by the warranty?
RTman10 wrote: Can you lock it down when it's off the bike?
No - but I can't do that with the other one either and that works fine...
Not sure then. Suggest you try the take apart solution but maybe a friendly call to your dealer before you do.
Sullivj wrote: When you try and press the handle down, is the foot on the back of the case, locking up in position?
Not sure what you mean by "the foot at the back of the case" - as far as I can see, there is no foot at the back of either case but I may be misunderstanding you...
Sullivj wrote: Having written all that, I now realise yours has central locking, which could be entirely different - I'm not sure.
It does - but I don't think that's the issue...
Apologies Richard, I have a 2012 bike, which I believe could be different to yours. Mine has an L shaped 'foot', that rises onto the frame when I lock the handle down.
Richard, if you're anywhere near Chester Motorrad pop in and speak to Harry he fixed one with a similar issue two weeks agorichardbd wrote: It does - but I don't think that's the issue...
Steve Parry BMW Motorrad (now KTM) sales executive current toys '15 R1200RT LE Dynamic. '14 F800GS ,'03 R1100S Boxercup, '85 R80RS Mono, 1990 K1
I didn't realise there were still 2012 bikes left on the road!
Sullivj wrote:
Mine's only done 4k. The previous owner didn't get out much!
or he disconnected the speedo...
