tyre life
Re: tyre life
JMRT
Re: tyre life
Post by JMRT »
Thanks Casbar!  I guess I will try this until it's time to park the bike for winter, hopefully I can stop the progress going forward otherwise I will have to buy a new front in the spring.
Re: tyre life
An interesting thread.  The thing to keep in mind when he talks about his 1600, 42psi is the recommended pressure in the front tyre.  With a 1600 on its centre stand it's very difficult to spin the front wheel as the weight on it is huge compared to the RT.  I reckon that 100  kg difference between the 2 bikes is all on the front.
Re: tyre life
I had a new tyre fitted a couple of weeks ago and am running it at 40 to see if that makes any difference as the tyre I took off was badly cupped (PR4GT).
gogs01
Re: tyre life
Post by gogs01 »
I've read some very good things and a lot of very bad things about PR4s.
Does anyone have anything bad to say about PR3s ? My experience of them has been nothing short of brilliant - handling, dry grip, wet grip at least as good as anything else I've used, and tyre life absolutely outstanding. I would be very reluctant to "upgrade" to PR4s.
Re: tyre life
gogs01 wrote: I've read some very good things and a lot of very bad things about PR4s.
Very bad things about PR4s - really. I think they have been really good. Think tyres are very subjective. Unless you do back to back testing I would say its really hard to know if a tyre is really bad. For me PR4GT have been great in both dry and wet. But then I am not a riding god.
scunny1
Re: tyre life
Post by scunny1 »
+1 on Michelin PR4s my K 1200GT had them and my current R1200RT LC has them both worked fine.
scunny1  R1200RT LE 2015
gogs01
Re: tyre life
Post by gogs01 »
Casbar wrote:Very bad things about PR4s - really. I think they have been really good. Think tyres are very subjective. Unless you do back to back testing I would say its really hard to know if a tyre is really bad. For me PR4GT have been great in both dry and wet. But then I am not a riding god.
Reading back through this thread, there is talk of PR4s cupping and having to be run at higher than recommended pressures, and tyre life less than half what I'm getting from my PR3s.
I'm no kind of riding god either and it's quite possible that I would be quite happy with PR4s, but I would be bitterly disappointed if they turned out not to perform as well, or to last significantly less than the PR3s .....
Re: tyre life
gogs01 wrote: Reading back through this thread, there is talk of PR4s cupping and having to be run at higher than recommended pressures, and tyre life less than half what I'm getting from my PR3s.
Not sure what mileage you get out of PR3s, I got just over 6k before I had to change my front tyre and it was cupped. So my new one, I'm running at 40 psi to see if that helps.
gogs01
Re: tyre life
Post by gogs01 »
Casbar wrote: Not sure what mileage you get out of PR3s, I got just over 6k before I had to change my front tyre and it was cupped. So my new one, I'm running at 40 psi to see if that helps.
From previous post :
My Michelin PR3s have done 8000 miles, including two European tours and a lap of the Nurburgring and now measure 3mm front and 4mm rear. Previous PR3s have been changed at up to 11,500 miles (front) and 7,600 miles (rear),but not necessarily down to the legal limit. I'm seriously impressed with these tyres !
Tyre pressures 36F, 42R. Mostly solo with topbox & panniers full. No unusual wear pattern.
mattye
Re: tyre life
Post by mattye »
Just to keep the thread going and to give me pennies worth i have just changed my rear PR4 with 8700 miles completed and changing the front with 11000 completed. Front has cupped a bit so time to change. And guess what i'm putting on? you guessed it another pair of PR4's.
8)
Re: tyre life
Gentle on the throttle and brakes then.
