I haven't had the RT long, but as soon as I got it, I put it in for the 24,000 mile service and everything due was done on it. However, I have noticed that when I get home after a run, I can smell what smells like hot oil. I have no drips of oil anywhere and the bike runs like a dream. Just wondered if anyone else experiences this, or any idea what it might be.
Thanks.
Smell of hot oil
Re: Smell of hot oil
I don't have this problem myself. Might be crank case venting to Air Box.
http://forums.bmwmoa.org/showthread.php ... IN-AIR-BOX
Check out the link. ???
Thanks Mike. I did wonder if it was slightly overfilled. Will double check the sight glass. I will also check the airbox as well.
- timminator
- Been liked: 2 times
If you just had it serviced, it's likely just oil that got onto the exhaust during the oil change. You could get down there and try to scrub it all off with a degreasing cleaner, but it should just burn off eventually. Keep an eye on the oil level and make sure it isn't leaking over time.
BMW MOA #210438
I have a similar smell, no leaks or obvious ones, no drips on the exhaust. If you do a search on the web it seems others suffer the same issue
I did do a google of this Duggie, and you are right, this is so common. I have had two other boxer engines in the past but have never had this smell before. From all the write ups, it doesnt apear to have any detremental affect on the bike or engine. Just annoying. I will try to check the airbox to see if there is any residual oil in there anywhere and maybe reduce my oil level as I am sure its a very full sight glass.
- Been liked: 24 times
Everytime I have had an RT dealer serviced the oil level has not been visible in the sight glass. (level above the top of the window). I queried this and have been told by differnt dealers that they put in a measured quantity.
Frogger, if you do check the air box lets us know what you find.
My oil level was just on the lower edge of the sight glass so for me it isn't the oil level, saying that I had a ride out today and had no issues with oil smells at all !
If you run around with next to no oil showing in your sight glass, the smell f oil will be the least of your problems. You should also have a low oil level warning light showing.
It's all topped up now, added 200ml to bring the level up, so it wasnt a problem and not low enough for the warning light to come on
