Pannier 'City lids' for R1200RT LC
elephant8869
Post by elephant8869 »
Does anyone know where I can buy the pannier city lids for the panniers on the liquid cooled RT? These are the replacement lids which reduce the pannier width by about 100mm?
Levisp
Re: Pannier 'City lids' for R1200RT LC
Post by Levisp »
You will only get aftermarket ones.  BMW haven't made them since 2004.
yellowjacket
Post by yellowjacket »
How about saddle bags for the RT LC that open on the top like the GS. I hate that everything tries to fall out every time you open them up.
richardbd
Post by richardbd »
yellowjacket wrote: How about saddle bags for the RT LC that open on the top like the GS. I hate that everything tries to fall out every time you open them up.
I agree.  The ones our cops use are just the job, although they are narrower (so hold less) than the OEM ones...
richardbd
Post by richardbd »
elephant8869
Thanks Richards, I've contacted nedplex and they do make slim lids for the watercooked RT panniers. Cheers
guest3459
Post by guest3459 »
I got mine from Nedplex - so far very good no problems
elephant8869
I found another slim pannier case manufacture/supplier in France called BCD http://www.bcd-design.com/en/catalog-bmw/
exportman
Has liked: 6 times
Been liked: 40 times
Post by exportman »
Hi
Purchased a set for my new 2017 RT from Nedplex Holland.  Arrived in 3 days.    They fit  but will not lock  the metal lugs are too short to engage with the pins
Sent them an email tonight  will post their response
exportman
Has liked: 6 times
Post by exportman »
Hi
They came back quickly and asked for photos,  however having a second look with a little more time  5 mins with a Dremel and all is good
I have not yet painted them  don't know if I will  may be in the summer when the weather is warmer.
richardbd
Post by richardbd »
Does the central locking still work?
And your reason for fitting them is?  Can't be filtering, if the front goes through so does the back.  They are designed that way. One of the advantages of the OEM is if you are unfortunate enough to drop it at a standstill (easily done).
, the lids save some very expensive bodywork and bits like end cans and drive shafts.
I never ride without them.
exportman
Has liked: 6 times
Post by exportman »
RTman10 wrote: And your reason for fitting them is?  Can't be filtering, if the front goes through so does the back.
Only if you are going in a straight line.
Wow must be a riding God, he can corner hard enough to scrape the pannier lids  8)
