Disc lock.
stayingupright
Re: Disc lock.
Post by stayingupright »
They could.
They could also turn up with a tail lift vehicle and be gone in under 20 seconds despite most security measures.
It's just a matter of another deterrent along with other visible security.
Oscar Nelsen
Re: Disc lock.
Post by Oscar Nelsen »
If you are concerned about forgetting to remove a disc lock, not that it ever happened to me, get one with an alarm. I have a Xena that has a shock and motion detector that beeps several warnings then lets loose a 120 dB alarm.
2016 RT
Pete1200
Re: Disc lock.
Post by Pete1200 »
If I am leaving the bike outside overnight away from home I use a chain around the crossbar of the centre stand, through the front wheel and back. Then I take up the slack by rotating the wheel forward and finishing off by putting a disc lock on between the caliper and the fork leg. It's a right palaver but as awkward for thieves as I can make it. Oh I dangle the disc lock through the fairing from the curly that is attached to the brake line by the ignition switch with a £1 shop carabiner.
I once had to move a Honda 90 with centre stand seized down and it was a right pig.
May the road ever be your friend, from leaving home till journey's end.
blokeonthemove
Re: Disc lock.
Post by blokeonthemove »
I think I'd be a bit concerned about squeezing the brake seals for an extended period of time.
Has liked: 32 times
Been liked: 33 times
Re: Disc lock.
Post by Sullivj »
If I'm leaving the bike for a prolonged period, I ALWAYS... Take the key out!
It's insured after all.
RTBoy
Re: Disc lock.
Post by RTBoy »
blokeonthemove wrote: I think I'd be a bit concerned about squeezing the brake seals for an extended period of time.
Exactly what I thought!!
gogs01
Re: Disc lock.
Post by gogs01 »
RTBoy wrote: Exactly what I thought!!
Not sure why you would be concerned - the system is rated to enormous pressure, and the pressure applied by the throttlelock is nowhere near maximum.  I certainly don't worry about having it on for short / medium periods.
