Garmin express 4.3.0.0 update now available
- stayingupright
Update now available
Last edited by stayingupright on Fri Nov 11, 2016 11:02 am, edited 1 time in total.
Re: Garmin express 4.2.0.0 update now available
Nothing shows if you just open it with nothing connected. probably update itself if you plug in your nav to do an update.
- stayingupright
I did a map update from Garmin express last week but could not tell you how old it was.
- stayingupright
Re: Garmin express 4.3.0.0 update now available
Garmin express can be updated without anything plugged into the computer
- stayingupright
RTman10 wrote: How. Nothing shows.
Go to the settings menu at the top of the express screen and drop down to "about"
It's in there
- Been liked: 333 times
Found a map update from 2017.10 to 2017.20, have started installing on both Computer and Device.
Looks like it's both a Garmin Express & map update.
- stayingupright
That was the one I got last week.
I should check this more often really
Last edited by stayingupright on Fri Nov 11, 2016 11:03 am, edited 1 time in total.
Found it but shows I already had 4.2.0.0. It offered 4.3.0.0 which has failed twice so I've given up..
- stayingupright
Damn!
Since posting about this the update has been updated
I'm now on 4.3.0.0
DaygloDavid wrote: What do Garmin Express updates do?
whatever it is, I bet they do it fast....
How long does the Garmin Express update take?
Currently still downloading files for the map update, now up to 4 hours 20 minutes.
Downloaded and installed in around 2mins DaygloDavid wrote: How long does the Garmin Express update take?
