Help for Fenix bullets fog lights and camera installation
Letsride
Post by Letsride »
Hello
New to bmw R1200rt, I would like to install some new Fenix Bullit fog lights on my 2016 rt, not familiar
With Bmw electricals. anybody have a video or pictures of an installation looking at the 12 v, the batterie
Is hard to get to.
I also have a Jvc camera that Inwould like to use to film my rides, any installation suggestions
Thank you again
Claude G.
guest3074
Re: Help for Fenix bullets fog lights and camera installation
Post by guest3074 »
You don't need to remove the battery to gain access to the positive terminal, just to the right of the battery is a small round plastic cover over a terminal, this is the main positive lead from the battery so pull off the plastic cover and you can undo the terminal to connect your lead  :)
Maz12
Post by Maz12 »
Benchmark wrote: You don't need to remove the battery to gain access to the positive terminal, just to the right of the battery is a small round plastic cover over a terminal, this is the main positive lead from the battery so pull off the plastic cover and you can undo the terminal to connect your lead  :)
Wish I'd known that when I was putting the lead on for my heated gear
Rossyuk39
Bike Model and Year: RT 2015
Has liked: 8 times
Been liked: 5 times
Contact:
Post by Rossyuk39 »
If you are installing many electrical "farkles", you could consider using a fusebox or distribution box (http://www.sportouring.co.uk/product-ca ... tions/sps/) and using a trigger to energise it when the ignotion is switched on. I have used one fro my Autocom, Ride+ camera, driving lamps and heated gear wiring looms.
Hope this helps.......
Keep on the grey bits .....Rossy
