Battery Charging
7vwh
Has liked: 12 times
Been liked: 33 times
Re: Battery Charging
Post by 7vwh »
RTman10 wrote: Will have to dig out my box to see if it gives any clue.
There's nothing on the box or the manual to suggest any manufacturers name RT.
Look st Just Bought a BMW battery Charger.  Mike says Made in Germany by BMW. Dont know where he found that.
guest3954
Post by guest3954 »
Its on the Box it came in. Just below the barcode.  :)
rogervk
Post by rogervk »
My new to me 2011 came with an Optimate 4 that came with the BMW plug. Prior owner bought the bike new and used the Optimate for his 5 years of owning it with no problems. I don't think they are that expensive bit I'm not sure. Good Luck.
BBT600
Post by BBT600 »
Hi Folks. I`m a newbie, took delivery of a 2009RT last month and put it in  the garage, haven`t looked at it since !  So I have a flat battery !!  The guy I bought it pointed out the socket on the left side of the fairing, I guess that is for plugging in a charger. Could you guys confirm for me please. I`ve also noticed chat about a optimate plug, is this the plug type that I need for this socket. Also, any advice on where to buy them would be much appreciated,
The socket is a BMW size ( not the normal phone charge type). If the battery has gone flat after only 1 month it's probably on  it's last legs.  If it's the original battery which is likely it's a heavy gel type and if allowed to go completely flat it might be terminal.
Your bike has Canbus wiring and needs a canbus compatible charger or you could damage the complete system.  Normal chargers can be connected directly to the battery though . If you buy the BMW charger it comes with the.correct plug and can be left connected for an extrnded  period. Available from any  BMW Bike dealer.
Been liked: 334 times
The BMW charger is £104.00, http://www.rainbowbmw.com/BMWETK/Produc ... 703003.php
The Optimate 4 BMW RRP is £79.99, http://accumate.co.uk/optimate%204%20bmw.htm
Nippy Normans are doing it for £69.00 with free delivery, http://www.nippynormans.com/k1200r/opti ... al-charger
The Optimate charger may even recover a neglected flat battery.
You pays you money and takes your choice.  You could try bump starting it for nothing.
If you do end up needing a new battery, you've got £35 towards the cost of it.
For another £15, you could have one of these, http://www.mdsbattery.co.uk/shop/produc ... oupID=9079
gogs01
Post by gogs01 »
DaygloDavid wrote: The BMW charger is £104.00, http://www.rainbowbmw.com/BMWETK/Produc ... 703003.php
I went for the Nippy Norman option. Seems to work great.
I wouldn't consider trying to bump start a bike as heavy as the RT (I presume that suggestion was tongue in cheek !)
Yep.  Back wheel never seems to go round.
futterweasel
Post by futterweasel »
gogs01 wrote: I went for the Nippy Norman option. Seems to work great.
The excellent Sportsbikeshop have the Optimate4 @ £53.99 free post
futterweasel wrote:The excellent Sportsbikeshop have the Optimate4 @ £53.99 free post.
The SportsBikeShop one isn't in stock & doesn't come with the BMW plug for the aux. socket, https://www.sportsbikeshop.co.uk/motorc ... prod/78250
gogs01
Post by gogs01 »
futterweasel wrote: The excellent Sportsbikeshop have the Optimate4 @ £53.99 free post
That's an excellent price but, as with most battery tenders, it is not advertised as canbus compatible, doesn't come with a Din connector (so can't be plugged in to the accessory socket on the RT) and you then have to find the battery and connect it to the battery terminals. Not the biggest job in the world but, for me, the Nippy Norman solution was the best value option.
You pays your money etc...
Mine was take it out the box , plug in both ends, forget.  With of course a 2 year warranty.  Didn't spend £16K  on a bike to scrimp on things to plug into,it.
