Nav V
Maz12
Nav V
Post by Maz12 »
map update now available..  2018.10
guest3074
Re: Nav V
Post by guest3074 »
Maz12 wrote: map update now available..  2018.10
Thanks, that's me updated  :)
stayingupright
Re: Nav V
Post by stayingupright »
Me too! ... Thanks
Quite a long update for me. It took about 45 minutes.
Re: Nav V
stayingupright wrote: Me too! ... Thanks
45 min, a long update, I wish.  Just done mine 5 HOURS.
Re: Nav V
Did mine earlier today, 45 mins max  8)  and it worked on the Mac - bonus
Re: Nav V
Casbar wrote: Did mine earlier today, 45 mins max  8)  and it worked on the Mac - bonus
Took me that long to find the USB cable.
stayingupright
Re: Nav V
Are you still on dial-up?
Re: Nav V
That was sometimes quicker.  Then again the last update took 20 minutes.
jjwill
Re: Nav V
Post by jjwill »
Thanks and now updated.  Approx 45minutes
gogs01
Re: Nav V
Post by gogs01 »
I had to get my nearly new Nav V replaced under warranty.
Registered and updated it, probably in less than 45 minutes - quite an achievement for someone with my level of computer expertise.
I'll find out if the updates are up to date next week when I'm heading down through England / France / Spain (avoiding tolls).
scunny1
Re: Nav V
Post by scunny1 »
Considering buying a Nav V, just a couple of questions. My 2015LC has not got the audio package but has speakers and blank switches. Does Nav 5 connect to these speakers, or are they just covers ,is there a speaker built into Nav V unit itself , or do I need helmet communication???  If I need connections to helmet, any recommendations ( I ride solo, so pillion comms is not desperately needed and I have Arai helmets )  Thanks in anticipation.
scunny1  R1200RT LE 2015
gogs01
Re: Nav V
Post by gogs01 »
scunny1 wrote: Considering buying a Nav V, just a couple of questions. My 2015LC has not got the audio package but has speakers and blank switches. Does Nav 5 connect to these speakers, or are they just covers ,is there a speaker built into Nav V unit itself , or do I need helmet communication??? If I need connections to helmet, any recommendations ( I ride solo, so pillion comms is not desperately needed and I have Arai helmets ) Thanks in anticipation.
I have an LC without audio, my brother has one with audio.  We both have BMW helmets with the BMW Bluetooth communicators. As far as I know, the satnav can't communicate via the audio system speakers.
I can't help with a recommendation for a Bluetooth device to fit your Arai - sorry.
richardbd
Re: Nav V
Post by richardbd »
I think you'll find your bike has speaker covers but no speakers.  I also think you'll find they're not blank switches, just moulded covers over empty holes.
Why would they install speakers or switches on a bike wth no audio system??
The Nav5 has no speaker or audio-out jack-plug, so you're down to a choice of bluetooth headset.  You will find plenty of threads on here with a variety of opinions on their merits.  Good luck choosing!
Taz
Re: Nav V
Post by Taz »
I have a 2016 RT without the audio package. The speaker covers are just that - there are large voids behind them where speakers could go. The buttons on the left lower side are blanks where buttons would go - the wiring behind has also been removed.
The Sat Nav will link through any Bluetooth helmet system.
Re: Nav V
You have two choices for connecting to your Nav and both are Bluetooth.  Either a full Bluetooth headset of whatever make you wish or a wired system like an Autocom with a Bluetooth dongle attached.  For me the advantage of the wired system is I can use more than one helmet as the headsets are relatively inexpensive and everything is bike powered.  You don't get bike to bike though.
