Small motorcycle compressor
Re: Small motorcycle compressor
I just plug my little compressor into the SAE plug that is used to charge the battery real easy.
- Has liked: 14 times
- Been liked: 6 times
Similar problems having brought a compressor with CanBus connector that took too much current. Solution for me was to get an adapter that connected directly to the CTEK battery strap! Luckily I found all this out when testing it not when needing it for real! Peter
Update:- waterproof switch came with an inline fuse and I've connected and cable tied under the seat, tried my compressor and ......................hooray worked perfectly thanks guys for your helpbe
Royal
Royal
