As I am a fairly early riser, I will be happy to post at any time (after 0630) if interested parties indicate the preference. Likewise people could indicate their opinions re the weather if there is a question.David. wrote: That's OK with me, however, Mike may need a little more notice, he is 2 hours from Wetherby.
Alternative 'Northern Monkeys' June Meet 2017
- k9doc
- Has liked: 5 times
- Been liked: 12 times
Re: Alternative 'Northern Monkeys' June Meet 2017
Chris
- Been liked: 337 times
Seems reasonable to me, just need to know what is the latest anyone would like to set off, to make Wetherby for a 10:30 departure.k9doc wrote:I will be happy to post at any time (after 0630) if interested parties indicate the preference.
As I'm less than an hour from Wetherby (route 1), I'd be looking to leave home at around 09:00, allowing time for a P&T stop at Morrisons.
- k9doc
Thanks David. Excellent link enabled me to find a tiny pinhole with the help of the window spray.David. wrote: Easy way to find a pinhole leak in your motorcycle tire, https://www.youtube.com/watch?v=wskeiycziZI
If the hole is as small as this, perhaps a vulcanised patch on the inside would be an alternative to making the hole bigger to fit a plug.
As there is plenty of life in the tyre, (and I prefer to change as a pair),I decided to contact Warranty Assist rather than risk a bodge. A BMW technician is due to arrive 1hr 15 mins after my initial call. Will update with the outcome but so far so good and thanks again.
Chris
Showers are fine. No fun if rain is continuous. We were planning to start out S.Cheshire 08:00 ishk9doc wrote: As I am a fairly early riser, I will be happy to post at any time (after 0630) if interested parties indicate the preference. Likewise people could indicate their opinions re the weather if there is a question.
From experience and as posted earlier, I certainly wouldn't be making the pinhole in the tyre bigger to fit any sort of plug/repair from the outside. IMO, this action will cause more damage to the tyre cords. For a professional job, the tyre should be removed from the wheel and a vulcanised patch fitted on the inside. The tyre will be as good as new.k9doc wrote:Enabled me to find a tiny pinhole. I decided to contact Warranty Assist rather than risk a bodge. A BMW technician is due to arrive 1hr 15 mins after my initial call. Will update with the outcome.
Let's wait and see how professional BMW warranty assist are!
- k9doc
Thanks for the info Mike. Will aim to post at ~0700-0730 unless otherwise advised.Mike wrote: Showers are fine. No fun if rain is continuous. We were planning to start out S.Cheshire 08:00 ish
Chris
- k9doc
Take your point, will see what the 'tech' has to say.David. wrote: From experience and as posted earlier, I certainly wouldn't be making the pinhole in the tyre bigger to fit any sort of plug/repair from the outside. IMO, this action will cause more damage to the tyre cords. For a professional job, the tyre should be removed from the wheel and a vulcanised patch fitted. The tyre will be as good as new.
Chris
What make is the tyre?k9doc wrote:As there is plenty of life in the tyre.
The proper way to patch a tire, https://www.youtube.com/watch?v=8aJmpcXnc5Uk9doc wrote:Take your point, will see what the 'tech' has to say.
- k9doc
Following on from some of the above posts re contacting interested parties.
In view of the current fiasco involving BA and the possibility of WIFI problems etc. What do people think about the idea of participants exchanging mobile #s with the 'event organiser(s)'. Gives a backup line of communication should the need arise.
Chris
+1k9doc wrote: Following on from some of the above posts re contacting interested parties.
- k9doc
@David
Well the tech came and plugged the tyre. Told him what you said but he said that if done from the inside it would still be reamed and plugged. Didn't feel like arguing for once. He had to stress that it was a temporary repair. Funny thing is my mate had the same thing done at the roadside by another BMW tech who said the repair was good for the life of the tyre. The upshot is that I may decide to replace the tyres sooner than anticipated as on closer inspection, the wear indicators in the centre of the tyre are closer to the limit than at first appeared.
The tyres are Metzeler Z8
Chris
A grand idea, k9doc (Chris) & I have already exchanged mobile numbers. If Chris is happy to be the contact for this event, that's fine with me.k9doc wrote:What do people think about the idea of participants exchanging mobile #s with the 'event organiser(s)'.
- k9doc
Fair enough by me.David. wrote: A grand idea, k9doc (Chris) & I have already exchanged mobile numbers. If Chris is happy to be the contact for this event, that's fine with me.
Chris
For many years and miles, I used Metzeler Z6's, they are a bit slick in the centre, similar to the Z8's.k9doc wrote:The upshot is that I may decide to replace the tyres sooner than anticipated as on closer inspection, the wear indicators in the centre of the tyre are closer to the limit than at first appeared.
The tyres are Metzeler Z8.
Got caught out in Scotland, set off thinking I'd easily get the trip out of the tyres, only for the rear to end up like the Z8 in the photo below.
Neither tyre has a tread pattern across the centre to monitor wear, for this reason I switched to the original Dunlop Sportmax Roadsmarts.
What new tyres are you thinking of getting?
- k9doc
Have used these tyres and their predecessors for years, Azarro, ST and have always had confidence (main consideration IMO) in both wet and dry. Never taken note of how long they last but they certainly do the job. Not the most popular choice I admit and probably not on the 'approved list'.
Chris
