Thanks for all the help folks! Went with the Wunderlich adapter to screw into the handlebar and a Ram ball stud to screw into that. Have a Ram suction cup mount as a backup. Looks like an easy clean set up that will take minimal tools to install / remove.
Now I need a bit of an assistance with a power outlet. Originally I thought I'd just run off the 276cx battery which has up to 16 hours of use, but with the screen on bright it decreases that time significantly. I can power the mount but would need to plug it into something. So, does the RT have a factory outlet? And where would it be located. Further, I'm assuming the European model, which I'll be on, has a different size socket if there is one?
Thanks for all the help, maybe a little more?
Need help / suggestions
- michaelc2710
- Has liked: 10 times
- Been liked: 29 times
Re: Need help / suggestions
Hi
The RT LC has 2 power sockets (one at the front and the other at the rear)
You can tap off from the rear off these and put your own power socket on if you need to. Just remember to use an in-line fuse
The one at the front should work. It's for a GPS that will mount between the bars. Trying to figure enough line length without having a ton of excess. Where abouts is the front socket located?michaelc2710 wrote: Hi
Thanks for the input
