Hex EzCan Install
Hex EzCan Install
Anyone using the new Hex Ezcan? I'm considering it instead of a PDM60 for my 2016 rt. It supposed to simply "plug into the can-bus" at the rdc module but I'm unsure where that is. Is the RDC the alarm module under the back seat? On the vendor videos, they appear to be plugging it in under the front seat. Thanks for any help!
Re: Hex EzCan Install
The rdc unit does sit behind the rear seat.
Current link shows the different units used by BMW.
https://www.motorworks.co.uk/bmw/prodimages/lg/ELE13340
Be good to get your views on this piece of kit if purchased
GJ-MOTO
- Been liked: 333 times
Is this any help, the photo shows a Clearwater CANopener installed in what looks like the rear of an LC RT.amsrk144 wrote:It supposed to simply "plug into the can-bus" at the rdc module but I'm unsure where that is.
These photos show that the passenger seat & rear rack need to be removed to gain access to the TPS.
GJ-MOTO wrote: The rdc unit does sit behind the rear seat.
Is there a model for the RT LC yet ?
Thanks for the responses. I just spoke with Matt, the "gear head" at Twisted Throttle. Very knowledgeable and extremely helpful. Turns out that the EZ-Can can be plugged in anywhere in-line to the Can-bus, it does not have to go into the RDC. I can now avoid removing the rear rack and simply plug it into a more convenient location under the front seat. It will read the bus signals from anywhere. I went ahead and bought it and will post how it goes.
It appears the EZ-can is now available for the full 1200 series, so yes it is available for the RT-LC, which is the bike I have.
http://www.twistedthrottle.com/hex-ezca ... 00rt-14-16gogs01 wrote:Is there a model for the RT LC yet?
Just for the record once you know where it is and have identified the connector there is no need to remove anything other than the rear seat to remove this connector and connect into it, I didn't amsrk144 wrote: I can now avoid removing the rear rack and simply plug it into a more convenient location under the front seat.
I have just fitted Hex ezCan to my 2014 RT. It's driving 2 auxiliary lights and a supply for a camera. It was a straight forward fit, connecting to the battery and the CanBus were straight forward.
If anyone has questions, ask them now whilst the fitting is fresh in my mind.
One morning I shot an elephant in my pajamas. How he got into my pajamas I'll never know. Groucho Marx
- timminator
- Been liked: 2 times
I have the Clearwater CANOpener3, and plugged into my TPMS. It's not necessary to remove the rear rack, just the pillion seat. I was able to easily reach inside the opening and unplug/plug the connectors. I suppose if you have very large hands, it might be necessary, but not for the average person.amsrk144 wrote: Thanks for the responses. I just spoke with Matt, the "gear head" at Twisted Throttle. Very knowledgeable and extremely helpful. Turns out that the EZ-Can can be plugged in anywhere in-line to the Can-bus, it does not have to go into the RDC. I can now avoid removing the rear rack and simply plug it into a more convenient location under the front seat. It will read the bus signals from anywhere. I went ahead and bought it and will post how it goes.
BMW MOA #210438
- Bike Model and Year: 2023 1250RT
- Has liked: 5 times
- Been liked: 3 times
I’m planning to install a Hex EzCan on my 2023 1250RT (which has RDC and DWA), and was wondering whether I have to remove the top case and rear rack (and/or the silver plastic cover that sits on top of the rear rack) in order to access the connectors that the EzCan plugs into? Also, I saw a video on YouTube, where the person said that in the last year or two, BMW made a change and that while the RDC control unit is no longer located behind the passenger seat, the connectors that the Ez Can plugs into are still located there. Does anyone know whether that is in fact correct?
If anyone happens to have pictures of the location of the connectors, that would be greatly appreciated. I keep this bike in a different state from where I live, and so I’ll be doing this install in a remote location (just prior to departing on a road trip), and am trying to avoid any surprises when I get into the job. Thanks.
- EasyRider
- Has liked: 87 times
- Been liked: 160 times
I have just fitted one to my 2019 R1250RT.
I connected it to the RDC without having to remove the top box or anything.
If its the same as mine, remove the pillion seat. The RDC is on the bikes right side (or your left as you look at it)
There is a push clip release each side of the plug and it then just pulls off.
I would post a photo, but i have all the cables for my bike cameras in there as well so you cant see much.
Thanks EasyRider. I appreciate the feedback.EasyRider wrote: ↑Mon Mar 18, 2024 11:11 am I have just fitted one to my 2019 R1250RT.
If anyone has installed one a slightly later model (2022 or later), can you please chime in. Thanks.
