2014- Switch of headlight after engine started
Admin
Post by Admin »
2014- Switch of headlight  after engine started::
Pres turn signal cancel button for 5 seconds, then without lifting it - flick the button right into the right turn signal mode - and keep it there for about 5 seconds
Main / Headlamp switches off
To enter normal mode - flick the signal horn
Maz12
Re: 2014- Switch of headlight after engine started
Post by Maz12 »
Does it turn back on if you start riding?
Probably not applicable if you have Headlamp Pro. But why would you want to?
STeinar
Post by STeinar »
Maz12 wrote: Does it turn back on if you start riding?
No you need to stop the Engine or press the full light switch for a second.
Using Tapatalk HD
STeinar
Post by STeinar »
RTman10 wrote: Probably not applicable if you have Headlamp Pro. But why would you want to?
Yes it dose also on my bike having headlight pro.
Using Tapatalk HD
STeinar wrote: Yes it dose also on my bike having headlight pro.
Using Tapatalk HD
If you have it set on Auto the headlight doesn't come on, just the Angle eyes.  Does it switch them off
STeinar
Post by STeinar »
Using Tapatalk HD
No only the extra two led lights, not the angle eyes.
Using Tapatalk HD
Bikerman1042
Post by Bikerman1042 »
I wouldn't do that. the headlamp on is a safety feature see and BE SEEN
Our Gee
Been liked: 24 times
Post by Our Gee »
"Sorry Mate, I Didn,t See You", "Isn't your bike suposed to have it's headlight on ". "What, you have disabled that function" !!. Dosen't take much imagination to see what comes next if it gets to court.
richardbd
Post by richardbd »
Am I missing something here?
Why would I ever want to switch off the headlight??
So nobody would see you when riding without a helmet on maybe. You need to be slightly deranged these days to have no lights on. With lots of cars having quite bright LED DRLs its just too easy to go invisible amongst them.  I like my angle eyes nearly as much as my chrome.  .
STeinar
Post by STeinar »
richardbd wrote: Am I missing something here?
In a service mode - sometimes you want the ignition on, but not to drain the battery - switch all light off !
Not for riding, but in service situations.
Also - sometimes - like on a track - you are not allowed to have any front light on - when riding ;-)
and so on  ^-^
Rossyuk39
Bike Model and Year: RT 2015
Has liked: 8 times
Been liked: 5 times
Contact:
Post by Rossyuk39 »
A similar method to the older models (upto 2010) - I have on occasions turned off my dipped beams depending on what is behind me or in low sun, so that I increase my contrast to my surroundings, increasing the chances of road users seeing me, instead of blending in :-)
Just a thought ......
Rossy
Keep on the grey bits .....Rossy
bandytales
Post by bandytales »
Well said, Rossy :)
futterweasel
Post by futterweasel »
yes i think you are missing something  :alas: :alas: :alas:
