Hello Team:
Anyone knows if using a pump/oil extractor will work on this engines?
I normally use the oil extractor in all my vehicles (bikes/cars) and works very fine. But wondering if the extractor will reach all the way to the bottom of the engine to suck out all the oil.
Thank you very much.
Oil change using an oil extractor (pump)?
- 2012 R1200RT (0440), 2011 HD Softail Fatboy and 2006 HD V-ROD VRSCR Streetrod.
- Been liked: 337 times
Re: Oil change using an oil extractor (pump)?
Most unlikely, the oil filler cap is on the RHS valve cover. From that position, there is no chance of getting a tube to the bottom of the sump.Zapata wrote:Anyone know if using a pump/oil extractor will work on this engines?
If you are looking for something to aid/speed up oil changes,
fitting a Quick Valve http://www.quickvalve.co.uk/motorcycles ... tm?veh=BMW,
or Stahlbus oil drain valve http://www.stahlbus.com/products/en/oil ... /index.php,
might be an alternative.
I like the idea of that Stahlbus drain gizmo but according to there web site it is only suitable for RT's until 2013 any one tried to fit one to an 2014lc? cheers.
The sump drain plug on a 2014 RT LC (K52) is M20 x 1.5, same as GS LC (K50), earlier RT's have an M16 x 1.5 plug.futterweasel wrote:I like the idea of that Stahlbus drain gizmo but according to there web site it is only suitable for RT's until 2013 any one tried to fit one to an 2014lc?
Therefore, the one for the GS should fit the RT, http://www.stahlbus.com/info/en/product ... rfilters=0
Available from Demon Tweeks in the UK, https://www.demon-tweeks.co.uk/motorcyc ... rain-valveLevisp wrote:I have a Stahlbus valve fitted to my 2014 RT LC and its M20 x 1.5 (SB-210511-S-NA).
Fitting a Stahlbus drain plug would remove the OEM magnetic plug.
If this is of concern, could always slap some magnets on the oil filter, http://www.magneticoildrainplugs.co.uk/ ... gnets.html
Yes good idea plenty available on ebay like these https://www.ebay.co.uk/itm/10pcs-10-x-4-x-4-mm-Strong-Rare-Earth-NdFeb-Neodymium-Oblong-Bar-Magnets/192411523782?hash=item2ccc9edac6:g:S9oAAOSwOA1aRPxu
much cheaper but very strong.
You can also use the magnets from old computer hard drives. Just take the hard drive apart and remove the magnets. They are very strong.
I do not understand why one would want to suck oil out rather then have it drain and flushing residue from the oil pan?
And I have seen these quick drain items and would never trust my bike to one. Just the added mass hanging out and down from the drain plug is calling road debris to hit me and cause a issue.
I think one need to just turn the wrench and get it done that way.
LAF wrote: I do not understand why one would want to suck oil out rather then have it drain and flushing residue from the oil pan?
Sorry I don't understand "Just the added mass hanging out and down from the drain plug is calling road debris to hit me and cause a issue"
I assume it refers to the Stahibus drain plug which projects further from the sump than the OEM plug and is therefore more exposed to accidental damage.
I've never found removing a sump drain plug to be a task crying out for a more complex and expensive solution, but maybe that's just me .....
- Has liked: 69 times
- Been liked: 99 times
gogs01 wrote: I've never found removing a sump drain plug to be a task crying out for a more complex and expensive solution, but maybe that's just me .....
+1.. what with sticking magnets on the oil filter as well? Sounds like it's creating more work to me :alas:
One of the advantages of both these oil draining systems is, once fitted, you don't need to continue to screw a Steel drain plug in & out of an Aluminium sump.
Have had experience of a sump drain hole thread becoming stripped on an RT by the plug not being fitted correctly or overtightened by a.n.other.
(Managed to recover sufficient of the thread using a plug tap).
Also, after having a car serviced, the sump drain plug partially worked it's way out, was finger tight, again by a.n.other.
David. wrote: One of the advantages of both these oil draining systems is, once fitted, you don't need to continue to screw a Steel drain plug in & out of an Aluminium sump.
You need to stop a.n.other. working on your vehicles! He's obviously related to N.O.Idea
