Battery drain
Battery drain
Hi All
Ive a 2005 RT. Battery drain is terrible. 24-48hrs parking and it’s goosed. Def not battery as replaced and problem persists. No GPS. Can some one point me how to remove the factory alarm as someone said that might be a culprit and I never use it anyway.
Thanks All
Declan
Thanks All
Declan
Re: Battery drain
One other possible cause. It’s possible to plug an adaptor into the accessory sockets to adapt then to a usb socket. These, with nothing attached can run a good battery flat overnight.
- Been liked: 480 times
Re: Battery drain
This article shows how to access the alarm unit on a 2013 TC RT to replace the batteries, https://touron2wheels.wordpress.com/201 ... ion-alarm/ might be similar on a 2005 Hexhead.ddevane wrote:Can some one point me how to remove the factory alarm.
Disconnecting the alarm unit may prove whether or not it's causing the battery drain. Don't know if this will result in any other problems.
- michaelc2710
- Has liked: 68 times
- Been liked: 79 times
Re: Battery drain
Hi ddevane, On a drain that can flatten a good battery in 24 hrs you would get a small spark when connecting the battery cables. Disconnect the battery and lightly touch the connector back on and you should see it.
Then disconnect the alarm and try the connector again, if it still has a slight spark then the drain is still there.
Alternator would be the next one to unplug in case the rectifier diode has gone, the rectifier controls the alternator output but will also drain a battery if faulty.
Just a thought, have you disconnected the battery fully and left it for 24-48hrs then reconnected/ tried to start the bike, just in case the battery is faulty.
Re: Battery drain
David. wrote: This article shows how to access the alarm unit on a 2013 TC RT to replace the batteries, https://touron2wheels.wordpress.com/2016/04/23/replacing-batteries-of-bmw-r1200rt-90-years-anniversary-edition-alarm/ might be similar on a 2005 Hexhead.
Thanks David
This helps but I’m still not sure how to disconnect the alarm entirely
Re: Battery drain
michaelc2710 wrote: Hi ddevane, On a drain that can flatten a good battery in 24 hrs you would get a small spark when connecting the battery cables. Disconnect the battery and lightly touch the connector back on and you should see it.
Thanks Michael
There is definitely a drain. Good advice to disconnect alarm but that’s what I’m not sure how to do. Welcome any instructions from anyone how to disconnect it.
Is rectifier diode commonly at fault and easier to replace than test adequately?
Re: Battery drain
Find your BMW R1200’s DWA connector & battery, https://www.youtube.com/watch?v=Gsc5P7Ir5rwddevane wrote:Welcome any instructions from anyone how to disconnect it.
DWA módulo de alarme, https://www.youtube.com/watch?v=_nsd5A8vKOg
Re: Battery drain
Thanks David. I can find the alarm box but I’m looking for instructions on how to disconnect the alarm entirely without affecting other components so it can be ruled in, or out, as cause of battery drain.
Re: Battery drain
Disconnect the alarm box & see what happens.
On bikes without DWA, the plug is blanked off, suggesting it doesn't effect other components.
HEX ezCAN R1200 Installation (BMW R-series) https://www.youtube.com/watch?v=X22HdaWOe-o fast forward to 5:00.
The blanking plug No. 06 has a resistor in it, http://www.realoem.com/bmw/enUS/showpar ... Id=77_0227, will probably need to be re-instated once DWA control unit is disconnected.
As a trial, disconnecting the unit & leave the bike for 24-48hrs will prove whether the DWA unit is causing the battery drain.
A more technical approach would be to use an ammeter & check the current draw on the battery, with & without the DWA unit connected.
Re: Battery drain
Thanks for patience David
Does DWA connector only resource the DWA ie won’t affect other components?
Thanks.
Declan
Thanks.
Declan
Re: Battery drain
From what I can see, the answer is yes, the DWA connector only supplies the unit itself.ddevane wrote:Does DWA connector only resource the DWA ie won’t affect other components?
If the trial or ammeter test proves the DWA unit is the cause of the battery drain & the unit is to remain disconnected, don't forget to fix the blanking plug (with resistor), it must be there for a reason.
Re: Battery drain
Thanks David
1. Definitely a spark there when connecting battery with ignition in off
2. Was getting 0.07amp draw
3. Disconnected that DWA plug. Seems to have reduced draw to 0.00-0.01
4. Will see what happens overnight.
Many thanks!
Declan
Many thanks!
Declan
Re: Battery drain
Hi David and all
So, battery drain does seem to be pointing toward alarm but Ive another weird problem which might be source of problem all along
When I start bike, and run for say 20-30mins, turn off, starter turns engine sluggishly and it wont fire. Back in again and I see battery is at 12.4v and thats not enough to fire (battery is 6 months old and this problem was present with previous battery....hence reason for changing battery in first place). Put onto chargeer for 30mins, and it fires fine. Im getting 13.85v at battery when running.
Any idea what the hell is going on.....
Thanks all
Declan
Thanks all
Declan
Re: Battery drain
ddevane wrote: Thanks David
4. Wll see what happens overnight.
Many thanks!
Declan
Hello!
The alarm unit has a rechargeable battery inside, and sometimes this battery needs to be replaced, or the unit will try to recharge ll the time - and taking power from the main battery.
I have not opened a alarm unit from the bike, så have no clue what sort of battery this is - or if its changeable or not without tools.
NB! A small spike when reconnecting the battery - do NOT by it selves indicated anything. There are capacitors and electronics inline - that will make a spike when power do come back (after reconnecting the battery) and this is normal.
NB! Even the GPS has a internal battery, and will also (re)charge if fitted - after reconnecting the battery !
STeinar
