Comfort screen
chrismckay
Comfort screen
Post by chrismckay »
Anybody got the BMW comfort screen fited and if you have how do you find it??
Re: Comfort screen
I used it in a 2009 RT for 2 years having removed the original low seat. Its 5mm higher than the low seat but 5mm lower than the normal seat on low setting.  It cannot be raised or lowered as you have to remove the height adjustment bits to fit it. Sold it in to a mate when I swapped to a K.  He still has it.  I found it an improvement and her behind said its the best pillion seat she ever had.
Re: Comfort screen
RTman10 wrote: I used it in a 2009 RT for 2 years having removed the original low seat. Its 5mm higher than the low seat but 5mm lower than the normal seat on low setting.  It cannot be raised or lowered as you have to remove the height adjustment bits to fit it. Sold it in to a mate when I swapped to a K.  He still has it.  I found it an improvement and her behind said its the best pillion seat she ever had.
Oops  Misread seat for screen.
beemerbaz
Re: Comfort screen
Post by beemerbaz »
Not heard of a comfort screen ?
chrismckay
Re: Comfort screen
beemerbaz wrote: Not heard of a comfort screen ?
larger option than standard  :)
beemerbaz
Re: Comfort screen
Post by beemerbaz »
Who makes yours ? I have a slightly larger one from CEE Bailey and find it a superb addition as I am taller than your averaged bear :-)
Re: Comfort screen
beemerbaz wrote: Who makes yours ? I have a slightly larger one from CEE Bailey and find it a superb addition as I am taller than your averaged bear :-)
[/quote
Just to clear things up. BMW have never made a larger screen for any 1200 RT until the 2014 model. There are some huge and not particularly nice after market ones around but unless you are quite tall or like looking through a screen all the time beware.  Those who have put mileage on the new one all seem to rave about riding in still air anyway.
chrismckay
Re: Comfort screen
[/quote
Thanks for pointing this out RT.....I presume the 2014 screen would not fit the earlier models?
Re: Comfort screen
[/quote
Correct, its totally different.]
bandytales
Re: Comfort screen
Post by bandytales »
chrismckay wrote: Anybody got the BMW comfort screen fited and if you have how do you find it??
What bike is it for?
If it is a Wethead, id forget about BMW Screens and go for either (in order of IMO, the best choice):
a/. Werks Quiet Ride
b/. Aeroflow
c/. CeeBailey
Been liked: 16 times
Re: Comfort screen
Post by beemerboy9 »
b/. Aeroflow
c/. CeeBailey
Forget option c) as CeeBailey are not longer making M/C screens - only aircraft now.
Qball-16
Re: Comfort screen
Post by Qball-16 »
If you're riding a HexHead, I would highly recommend the ZTechnik VStream.  Compared to the stock windscreen, the VStream is MUCH quieter, has a hugely expanded wind-free zone, very minimal visual distortion at the edges & curves, and they have a standard or tall versions.
guest2383
Re: Comfort screen
Post by guest2383 »
Bought one from another member (different forum) (a Cee Bailey I seem to remember) simply because I'm a magpie - never fitted it and don't think I ever will.
Probably because I'm a short arse and happy behind the standard screen.  :beee:
Been liked: 335 times
Re: Comfort screen
chrismckay wrote:I have just taken ownership of a 2012 RT1200 SE.
bandytales
Re: Comfort screen
I can't see that post on this thread! I don't have a time date code matching that at all?
So if it's for a Camhead, ignore my drivel because i know nothing about that bike.
Sorry.
