2012 R1200RT won’t start. Neutral wire? Terminal 15 - 0.00v
Bastian
Post by Bastian »
I have a 2012 R1200RTP I recently bought and it wont start. Screen lights up fine.
Hooking it up to a friends ICOM it shows that there’s no voltage on Terminal 15, also called KL 15. See screenshot.
ICOM shows all OK on sensors for starter button, clutch, neutral sensor and side stand.
Seems little voltage is getting to the fuel pump. Have tried already to bypass the FPC. Makes no difference except for that the fuel pump runs.
No voltage to starter or fuel pump, but they work fine if I apply 12v directly.
Digging a bit deeper I think it might be a loose ground wire, but I have no idea where the ground wires are.
I hope someone can point me in the right direction.
Sprintgull
Re: 2012 R1200RT won’t start. Neutral wire? Terminal 15 - 0.00v
Post by Sprintgull »
Do you get lights etc?  Is there anything on your box of tricks that checks out if the kill switch may have a fault?
Bastian
Post by Bastian »
Yes, I do get lights, horn etc. With ISTA / ICOM all the usual suspects (starter switch, clutch, gear sensor, side stand, EWS) check out OK.
Has liked: 105 times
Been liked: 242 times
KL 15 in BMW terminology = ignition is in the on/run position and all accessories are ready. Like you say, if all the cut off switches ie, kill, starter, side stand are showing fine? I'd be looking for a break in the wiring or a bad ground. Hope you get it sorted 👍
Ganesh
Post by Ganesh »
Hi, might not be the same problem mine had and the solution was simple when isolated. Everything lit up on mine properly just refused to start. The AA guy hot wired the starter and it fired up fine. It came down to the start/kill switch fault.  I dismantled the switch took the plastic outer off, used the buttons on the sealed unit and it fired up fine. The plastic outer wasn't alowing the rocker to close the connection on the sealed switch. New switch, £120.
As I said might not be the same problem but see if it works. Usually the simple things we miss.
thanks and regards, Ganesh
Side stand kill switch.  But more likely the kill switch.  It was a known fault back in 2012 and was replaced FOC if it failed for some time but not now.
futterweasel
Post by futterweasel »
Well if you are not leaving i'll have me [font=]CHEERIO BOR back!!!  ;) [/font]
Bastian
Post by Bastian »
Its was the ECU which somehow blocked the bike from starting. Got a second hand ECU+key kit from eBay and now the starter motor works but the bike still won’t start. Here’s a YouTube video with the sound. Let me know if anyone has any suggestions.
https://youtu.be/SAkhnspD0Vs
Bastian
Post by Bastian »
Solved it! Problem now was the battery which through all of the experimenting lost some of its power. New battery and everything is great again.
B
Bastian wrote: Its was the ECU which somehow blocked the bike from starting. Got a second hand ECU+key kit from eBay and now the starter motor works but the bike still won’t start. Here’s a YouTube video with the sound. Let me know if anyone has any suggestions.
mack62
Post by mack62 »
Where is the ECU on this vintage bike?  I am looking to get mine remapped and need to find it first.
2013 R1200RT 90th Anniversary
Bastian
Post by Bastian »
Under the fuel tank
