Has anyone had experience in fitting a Denaili Soundbomb to a 2018 RT 1200 LE , is it possible ?
Many thanks
Denali SoundBomb
- michaelc2710
- Has liked: 10 times
- Been liked: 29 times
Re: Denali SoundBomb
Hi Shahed
It's very easy, it took less than an hour from start to finish.
I removed the O/S fairing and ran the wiring down to the battery between the tank and the plastic cover and fitted the relay under the seat, a big improvement on the BM horn
How did you get on with fitting the Denali ? Did you need to buy the full wiring kits?
I fitted a Denali soundbomb mini, used a couple of spare brakets I had knocking aroud, bought the adaptor cable from nippy normans - no relay or hex can needed, It's plenty loud enough for me.
HTHNick
HTHNick
