Torx set
Re: Torx set
Some handy looking tools [emoji106]
- Been liked: 337 times
Re: Torx set
By purchasing this, https://www.machinemart.co.uk/shop/prod ... of-bit-set,
& a 19mm 3/8" Drive Socket, https://www.machinemart.co.uk/shop/prod ... -drive-met,
I've been able to slim down my tool kit considerably.
All items except, https://www.machinemart.co.uk/shop/prod ... ils/pro199, now fit into a soft spectacle case.
It looks like the above will also fit under the seat, then I'm sorted.
Re: Torx set
Purchased the Clarke PRO199 3/8" Drive Extendable Ratchet today, yes it goes under the seat, complete with the soft spectacle case for the other tools.
Unfortunately, can't use the tool roll, but easily sorted with two freezer bags.
Re: Torx set
I'm new to BMW ownership.
I've always owned totally faultless Italian bikes before.
How worried should I be that one of the main threads on here is about the size of the tool kits people carry on their RTs??
:not: :not: :not: :not:
[size=78%]
[/size]
[size=78%]
[/size]
[size=78%]
[/size]
[size=78%]
[/size]
Torx set
I wouldn't be worried at all. I only carry the tools I am capable of using which is the OEM set or similar replacements. I guess the planned trip might also determine which tools and what to take, I would probably take something extra if I was going to Morocco as opposed to nipping up to Scotland.. 1 essential tool is a small piece of plastic which fits in my wallet and says BMW Assist on it [emoji12]
Re: Torx set
Like beemerbaz, the only tools I carry are those which would come in the Standard Toolkit or an equivalent replacement.
With these tools, (screwdriver with star-head blade & T30 Torx wrench respectively), the Rider's Manual suggests they can be used to,
replace the brake-light/rear-light & rear-indicator bulbs, plus removing the flashing turn indicator with fairing panel.
BMW Motorrad offer a supplementary service toolkit, "ideal for carrying out extended service work (e.g. removing and installing wheels)".
http://www.bmw-motorrad-store.co.uk/bmw ... ycles.html
The additional tools which I have assembled will do the same as the above, probably for about half the price or less.
Together, they all take up minimal space & fit under the pillion seat.
Re: Torx set
A local BMW Dealer has suggested the Service Kit Part No. 71607714570 for a 2012 RT, at a cost of £126.
http://www.rainbowbmw.com/reshop/index. ... uct_id=212
Re: Torx set
The CruzTools 10-Piece Star Bit Set http://www.cruztools.com/products/socketbits.html, looks ideal, includes all sizes required, T10, T15, T20, T25, T27, T30, T40, T45, T50, T55.
With a 3/8" Drive Socket Wrench, the job is sorted.
Re: Torx set
Just ordered a Silverline Torx Key T Handle 10pc Set from FFX, https://www.ffx.co.uk/tools/product/Sil ... 0Pc-T9-T50, great price too.
- Sprintgull
Re: Torx set
My set arrive today, a nice addition to the tool box.Sprintgull wrote:Just ordered a set myself.
Was able to access & loosen the mirror securing set screw. This screw was previously too tight for the torx keys I had, not enough leverage available with this type.
- Sprintgull
Re: Torx set
Mine arrived today too. I've got that other set too. You can never have too many...….
- smileymiley
- Has liked: 4 times
- Been liked: 11 times
Re: Torx set
A set is winging it's way to me now Thanks for the heads up David
