Hi, went out for our first two-up ride on the R1200RT this weekend. My wife is tall, and she's complaining that her legs are bent up pretty tight on the footpegs.
Is anyone using or can recommend a set of lower or adjustable rear footpegs for a 2005 model ?
Thanks
Mat
Passenger footpegs
- Been liked: 334 times
Re: Passenger footpegs
This passenger footpeg lowering kit will fit all R1200RT's, https://www.nippynormans.com/wunderlich ... g-lc-model
You could try this company, slightly cheaper & adjustable.
https://www.motorworks.co.uk/vlive/Shop/Parts.php?T=5&NU=15&M=35&Ct=MA&SbCt=BA_15_35_MA_39
Does anyone know if the rear footpeg mounts are the same on an R1200RT and R1200GS of the same year (2005-2013) ?
I've seen quite a few lowing bracket sets advertised for the 2005 R1200GS, but only a couple for the RT. The GS ones are significantly cheaper.
Thanks
Mat
Thanks
Mat
R1200RT 05-09 (K26), #04 46 71 2 310 403 FOOTREST, REAR LEFTmatgriff wrote:Does anyone know if the rear footrest mounts are the same on an R1200RT and R1200GS of the same year (2005-2013)?
R1200GS 05-07 (K25), #07 46 71 2 310 403 FOOTREST, REAR LEFT
matgriff wrote: Does anyone know if the rear footpeg mounts are the same on an R1200RT and R1200GS of the same year (2005-2013) ?
Thanks
Mat
If you email Nippy Norman they will tell you what fits yours. Ive found them prompt and helpful.
Thanks for the parts fiche, according to that they are both the exact same part number for the left and right rear including rubber for both bikes :-)
That's good, I'll take a closer look at the GS lowering mounts and see if there's any reason they won't fit the RT
Thanks
Mat
Thanks
Mat
