Windscreen
mondeoman
Windscreen
Post by mondeoman »
Just changed my 2013 RT to a early 2016 RT LE,  one feature is that when you switch off,  the screen retracts to it's lowest position and automatically returns to it's previous position as you move off,  I would like to disable this feature but can't spot the ability to do this in the menu's,  does anyone know if it's possible to disable this or not.  Image
Mondeoman
Has liked: 39 times
Been liked: 38 times
Re: Windscreen
Its not possible I'm led to believe
mondeoman
Re: Windscreen
Post by mondeoman »
Looks like I'm stuck with it Bob Image
Mondeoman
bandytales
Re: Windscreen
Post by bandytales »
mondeoman wrote: Just changed my 2013 RT to a early 2016 RT LE,  one feature is that when you switch off,  the screen retracts to it's lowest position and automatically returns to it's previous position as you move off,  I would like to disable this feature but can't spot the ability to do this in the menu's,  does anyone know if it's possible to disable this or not.  Image
Why would you want to?
Been liked: 16 times
Re: Windscreen
Post by beemerboy9 »
To clean the inside of the windscreen? - the answer is to turn on the ignition and raise the windscreen.
bandytales
Re: Windscreen
+1
smileymiley
Has liked: 4 times
Been liked: 11 times
Re: Windscreen
Post by smileymiley »
+1
mondeoman
Re: Windscreen
Post by mondeoman »
I'll have too then.
Mondeoman
bandytales
Re: Windscreen
mondeoman wrote: I'll have too then.
Yep. And as a bonus, you can listen to the radio at the same time (if you have it fitted - and have the 'speakers attached ...I took my 'speakers out to give me a load of storage space).
