Anyone tried this?
https://www.nippynormans.com/r1200rt-lc-2014-on/autosol-bluing-remover
Blueing
Re: Blueing
Yes, I used this on my last R1200RT exhaust pipes. It is acid based for use on stainless steel & titanium.
It worked remarkably well & restored the pipes to as new condition. Great stuff!
Re: Blueing
dengieken wrote: Yes, I used this on my last R1200RT exhaust pipes. It is acid based for use on stainless steel & titanium.
Thanks for that, Does it last a reasonable time and do you still use it.
Re: Blueing
I did it a two or three times a year from memory. I don't use it now because I have chrome pipes on my R1250RT
Re: Blueing
dengieken wrote: I did it a two or three times a year from memory. I don't use it now because I have chrome pipes on my R1250RT
I wonder if mine are chrome. They are discolouring. Is this not suitable for chrome pipes?
Re: Blueing
My understanding is that the stainless exhaust goes brown, and the chromed exhaust goes blue/purple.
I'm getting the stainless headers on my '06 RT ceramic coated, primarily for the heat reducing benefits, but I'm also tired of polishing the blue/purple out of them...
Re: Blueing
Copied this from the brochure,
* “Stainless steel exhaust system with sound flap.”
Mine are blueing
Mine are blueing
Re: Blueing
It does'nt work on chrome pipes, guess how I know ! I've also tried Optiglanz, this also does'nt work on chrome but works superbly on stainless steel (as long as the stainless is NOT chromed)
Mondeoman
- Been liked: 334 times
Re: Blueing
StainlessQball-16 wrote:My understanding is that the stainless exhaust goes brown, and the chromed exhaust goes blue/purple.
Chrome
Re: Blueing
2016 R1200RT, these look like chrome.
This guy used some #0000 grade steel wool & Blue Away.
Re: Blueing
Just noticed this in the brochure for the LE,
R1200RTLE Additional Equipment
· Dynamic ESA
· Preparation for GPS Device · Heated Seat
· Cruise Control
· Additional Power Socket
· Gear Shift Assist Pro
· Chrome Exhaust *******
· Central Locking System
· Tyre Pressure Control ·Anti-TheftAlarm
Is that chrome on stainless steel ?
· Dynamic ESA
· Cruise Control
Re: Blueing
Beagle wrote: Just noticed this in the brochure for the LE,
· Dynamic ESA
· Cruise Control
Is that chrome on stainless steel ? I would love to know the answer to this, since the chromed exhaust usually show rust pitting you would logically assume the the underlying metal is mild steel, stainless of course shouldn't show any sign of rust.
Mondeoman
Re: Blueing
Very interesting result, but, it looks like due to the use of wire (steel) wool the reflective sheen of the chrome has been dulled by what will be a myriad of microscopic scratches caused by the abrasive quality of the wool , nonetheless it's an improvement, I think :wonder:
Mondeoman
Re: Blueing
There is different quality of stainless depending on chromium content. My old K100RS had stainless pipes but showed surface rust over winter storage.
The other thing is when you clean off the blue, how long before its back.
Re: Blueing
NEVER USE STEEL WOOL ON YOUR CHROME OR STAINLESS STEEL EXHAUST.
It is a lazy man's route to disaster.
It can ruin both materials. The reason we chrome is to put a barrier of other materials ON TOP of the steel (or stainless steel) to prevent corrosion (and make it look pretty). The moment you use steel wool, you are scouring (potentially) through the chrome and also laying the way open for dissimilar metal corrosion.
STOP DOING IT!
