Water Cooled Battery Model
guest5886
Post by guest5886 »
After less than two years the battery on my 2017 RT has started to display the typical symptoms of a BMW OE battery: it's dying out.  :)) Symptoms are the usual: instrument cluster goes blank when turning the bike on and then resets to the RT logo.
Tomorrow I'll drop by the BMW dealership to see if I can get a new one under warranty. So far they have always been very helpful but this is Italy so I wouldn't be too surprised nor angry if BMW weren't too keen on replacing batteries for free.
As a backup plan I'd like to know what battery model I can fit because 1)I can get good deals on Yuasa and Fiamm batteries 2)I am not going to pay that kind of money having a story with OE batteries from BMW.
I've read the YTX20CH-BS is a straight fit but I'd like to have confirmation.
Thanks in advance.
PoorUB
Re: Water Cooled Battery Model
Post by PoorUB »
Yuasa shows a YTX14H-BS or GYZ16H fitting the '14-'16 RT. I believe they are the same all the way up, so either of these should fit you '17 RT.
guest5886
Post by guest5886 »
The GYZ16H is the Yuasa equivalent of an Odyssey battery, only it costs twice as much.  :)) Joking aside the monster price is due to it being a US-specific model brought here through parallel import channels.
I'll drop by at the dealership tomorrow to hear what they have to say and keep you posted.
guest5886
Post by guest5886 »
I contacted the dealership and BMW will "most likely" replace the battery under warranty, albeit said replacement is subject to a battery load test which will be performed in a few days.
The dealership suggested an YTX20CH-BS battery as an aftermarket replacement (obviously off the record) and it's nice to have a fallback plan in case Mr BMW turns me down.
guest5886
Post by guest5886 »
Battery replaced under warranty, meaning more money for fuel and rubber.  ;)
daverj
Post by daverj »
Good result.
R1250RT LE
