Mandatory speed limiters
- Has liked: 25 times
- Been liked: 52 times
Watching the BBC News this morning, they covered a story about all vehicles all be fitted with speed limiters in the UK from 2022. They talked about cars and lorries but didn't mention motorbikes.
However, the article on their website states all vehicles.
https://www.bbc.co.uk/news/business-47715415
Be interesting to see how this turns out. They mention that the system can be overridden or switched off, so what's the point? People that drive at excessive speeds routinely are simply going to turn it off every time they get in the car.
Re: Mandatory speed limiters
MikeS wrote: Watching the BBC News this morning, they covered a story about all vehicles all be fitted with speed limiters in the UK from 2022. They talked about cars and lorries but didn't mention motorbikes.
Sometimes the satnav indicative speed is not the same as actual roadspeed limit eg out of date.
- Been liked: 334 times
Cruise control can already be used to limit speeds.
The signed speed limits are the ones to be observed.
David. wrote: Cruise control can already be used to limit speeds.
Does anyone know where does the satnav pickup speed limits. Speedlimiters wont read the signs.
http://www.drivingexpert.co.uk/all-abou ... iters.html
My understanding is that the speed limits are incorporated into the mapping software that the sat nav uses. If they've changed the speed limit on a particular road since the last map update then it gets it wrong. On my Garmin I not sure that even the latest updates get it correct, there must be some delay between changes getting reported and being put onto the maps.
"Although the Garmin speed limit information is very accurate, it is still up to you to be sure you continue to look for the speed limit signs on the roads."
"The GPS unit is a tool to ASSIST you with navigating. It is not an absolute. Never rely on it implicitly. And always follow the local signage. The database (whether it be roads, speed limits, or POIs) is NEVER going to be 100% accurate."
MikeS wrote: http://www.drivingexpert.co.uk/all-about-active-speed-limiters.html
I agree with my honourable friend. ( Sorry watching too much Parliament )
Some cars have systems that read the speed limit signs. Not driven one so no idea how well they work
https://www.bbc.co.uk/news/technology-32049350
I've got a Mondeo with sign recognition on it - pretty good most of the time and shows more than just the speed limit signs - it can show up to two different signs at once although I have to say, it doesn't always do that.Just waiting for it to be collected this morning as I am retiring today :clap: :clap:PeteM wrote:
Interesting, when there is a reduction in the signed speed limit, you need to be at the new lower speed limit before or as you pass the sign.PeteM wrote:Some cars have systems that read the speed limit signs.
Likewise, where the speed limit increases, your speed needs to be maintained until you've passed the sign before accelerating.
So let me see if I have this correct. Technology has given drivers a system where the speed limit road signs show on the dashboard. So while the driver is looking head inside the car he misses a possible danger outside car. Looking outside he sees the speed sign and the danger. Sounds like another crappy safety idea to me. Automating speed will IMHO not reduce accidents. It will make drivers even more dozy. All that will happen is that accidents will occur at the legal speed limit it will not prevent them. If you want to reduce road accidents then improve driving standards !
Automation in the aircraft world has sadly just caused two fatal accidents. The Boeing 737Max anti-stall system failure has flown the aircraft into the ground. When I was flying we were taught how to recognise a stall and flying the aircraft away from it. Yes we had stall warning systems but the aircraft did not takeover from the pilot. The automatic system was the pilot. As you take the human away from control the ability to recognise a situation and take appropriate action diminishes. This is not to say some automatic safety system are bad. Antilock bake systems for one is a good system.
Making drivers detached from driving is going to be a place I don't want to be. Unfortunately we are all already there in so many ways.
Post test training with the likes of IAM, RoSPA or others would be a good start.Levisp wrote:If you want to reduce road accidents then improve driving standards.
David. wrote: Post test training with the likes of IAM, RoSPA or others would be a good start.
Child runs out in front of your bike in a 30 limit, nothing you can do to avoid hitting it but sadly the child dies.
You are doing 30mph....... its not your fault.
You are doing more than 30 mph......... you are charged with causing death by dangerous driving.
- Has liked: 68 times
- Been liked: 99 times
Yes, but if you were doing more than 30mph you'd have already gone past when the child ran out. Therefore saving the child's life.
