LC mirror removal
Duggie
LC mirror removal
Post by Duggie »
Has anyone taken a mirror off a r1200rt LC model ?
I caught mine on a barrier and damaged the plastic casing, so I now want to replace the casing.
Is there a way of removing the casing without taking the mirror off the bike ?
Any help appreciated.
Duggie
Sprintgull
Re: LC mirror removal
Post by Sprintgull »
Yes it can be done because mine came off after a filtering misjudgement.  :-X
Clipped on from memory.
Boxflyer
Been liked: 16 times
Post by Boxflyer »
Hello Duggie...I think this is what you are attempting to do...2014-2018 RT LC
This is for the RH side.  The LH side is similar.
Hope this helps.
Duggie
Post by Duggie »
That’s brilliant, just what I needed, thanks.
Regards
Duggie
Steve F
Post by Steve F »
Sprintgull wrote: Yes it can be done because mine came off after a filtering misjudgement.  :-X
Likewise, I’ve had cause to clip the LH mirror rear fairing back on after knocking it against a tall plastic road works bollard overseas last year. Yes, it just clipped straight back on, having seen it hanging like a displaced eyeball on its retaining lanyard!!
