Cylinder head protection
hammo
Been liked: 20 times
Re: Cylinder head protection
Post by hammo »
Head covers will only protect the covers if you lose your balance and the bike catches you out thats all , obviously if you want full protection in the event you drop your bike you will require engine protection bars and pannier protection for the rear , Illium Works demonstrate their bars on you tube with an actual drop of the bike (Ouch!!!) but they obviously do the job but they are not cheap .
Hors Piste
Post by Hors Piste »
The slightly odd thing about that video is that they don't show you the bike after it's been picked up.  Still, I'm sure everything was OK  ^-^
R2K
Post by R2K »
R1250 MACHINEART
Kunkies
Post by Kunkies »
I have also installed the MachineartMoto X-Head.  They look great, don't seem to cause any heat problems (the valve covers don't get HOT anyway), and I did extensive research to ensure whether it's a tip over or low side slide out (don't ask), they will more than protect the magnesium valve covers from bleeding out engine oil.
Installation was a breeze, ~30 min. for both sides.
-Bob
Norcal1
Post by Norcal1 »
I also went with MachineartMoto X-Head for my 1250RT and they look fantastic. Went on a ride this weekend with another RT who had the crash bars and he said he is taking them off and puting on the X-Head. They just look so much better on the RT than crash bars. Moto-X  has a video also on there drop results. It is all ones choice, just glad there are choices.
Norcal1 wrote: I also went with MachineartMoto X-Head for my 1250RT and they look fantastic. Went on a ride this weekend with another RT who had the crash bars and he said he is taking them off and puting on the X-Head. They just look so much better on the RT than crash bars. Moto-X  has a video also on there drop results. It is all ones choice, just glad there are choices.
It's about protection not looks. Great there are choices.
R2K
Post by R2K »
It’s actually about both, with a priority on protection.  I always consider the esthetics when adding Farkles considering function first.
R2K wrote: It’s actually about both, with a priority on protection.  I always consider the esthetics when adding Farkles considering function first.
Well there you go then. i consider protection first and the cost if I drop the bike over the looks. My Illium bars look fine and I know they will work as the owner has a vid showing the bike being dropped on the Illium site. Had cylinder head protectors only on my 2014 but I bought that used. So on my new bike I decided to go with bars. Can anyone post a vid of a bike being dropped with just cylinder head protectors on for comparison.
R2K
Post by R2K »
8 https://m.youtube.com/watch?v=IuXQs5lRr ... e=youtu.be
R2K wrote: 8 https://m.youtube.com/watch?v=IuXQs5lRrKk&feature=youtu.be
Thanks, but that isn't an RT with all the plastic and panniers. Just for clarity, I'm not bothered what anyone fits to their bikes its a personal choice, I'm just interested if the cylinder head protectors would help with damage to the plastic and panniers, I understand they will protect the cylinders.
Been liked: 16 times
Post by beemerboy9 »
My 2014 RT with BMW head protectors dropped very awkwardly on a downward car park ramp - top box on, no panniers. There were 4 points of contact  - the replaceable black plastic insert on the head guards (replaced cheaply),the LH bar end (touched in with paint stick & rotated so that it count not be seen),the underside of the passenger grab rail (touched in with paint stick) and the rear light unit (which I replaced since it was chipped). So this time I have gone with crash bars.....
