Posts: 1386 Joined: Fri Sep 16, 2016 10:33 pm
Has liked: 69 times
Been liked: 100 times
Post
by simbo » Fri Apr 17, 2020 5:38 pm
David. wrote:
These nuts are described as 12 point or bi-hex, they are useful where access is limited.
Hence why a suitable socket is required, a 6 point or hex socket won't work.
Yeah, a 13mm what I like to call cheap socket fits a treat.
[attachimg=1]
Posts: 8088 Joined: Fri Nov 07, 2014 7:29 pm
Been liked: 341 times
Post
by David. » Fri Apr 17, 2020 6:08 pm
As
"field tested" on a GS.
Old-Git
Posts: 290 Joined: Sun Jul 30, 2017 8:21 am
Post
by Old-Git » Sun Apr 19, 2020 8:49 am
Ok so my bike goes up on the ramp today, service this week (if the oil filter arrives..) and I'm gonna make sure I can get the headers off before ordering the black widow set. I'm gonna soak them in plus gas, use heat (blowtorch), find a really tight socket. I've had advice to try nail varnish remover, tightening the nut ever so slightly. Any other hints, tips, tricks? Ta.
gogs01
Posts: 628 Joined: Mon Jan 12, 2015 8:32 am
Post
by gogs01 » Sun Apr 19, 2020 9:31 am
Last year I removed the silencer, then the header assembly to give my bike a deep clean. (It's a 2017 model bought and registered in 2016)
The nuts holding the headers to the cylinder head looked like those in the pictures posted by David of the GS headers.
I assumed they were external Torx nuts and used an external Torx socket (I could check the exact size if it would help).
The nuts came off and were replaced without any problem, other than the conflicting numbers for the make-up torque.
I'm no expert, but I don't think a 12 point socket is the tool to use.
Has liked: 69 times
Post
by simbo » Sun Apr 19, 2020 10:21 am
Yes that would help if you think it's the correct information.
Post
by David. » Sun Apr 19, 2020 10:25 am
My understanding is that Torx fixings are 6 point.
This is an example of a M8 exhaust manifold nut with both internal & external fitting.
Typical Dimensional Specifications of TORX Sockets or Nut drivers
For use with External TORX Head Type Bolts.
Socket E-Size Inch Metric
E-14 .503" 12.85mm
https://forums.bmwmoa.org/showthread.ph ... eader-nuts
David. on Sun Apr 19, 2020 10:55 am, edited 1 time in total.
Has liked: 69 times
Post
by simbo » Sun Apr 19, 2020 11:06 am
I've got a Torx set as my Triumph has quite a few of them fixings, the BMW manifold bolts are nothing like.
[attachimg=1]
Old-Git
Post
by Old-Git » Sun Apr 19, 2020 3:26 pm
Success! All 4 off, copious amounts of plus gas, a bit of heat, and off they come. Thanks to Simbo for the tip re an old 13mm socket.
Post
by David. » Sun Apr 19, 2020 3:33 pm
Excellent news, pleased you got there in the end.
Old-Git
Post
by Old-Git » Wed Apr 22, 2020 11:27 am
Exhaust arrived, I'll take pics and do a weight comparison later in the week.
Post
by David. » Fri Apr 24, 2020 7:15 am
Wow, that's good service from BW, look forward to hearing how you get on with your local bike dealer and any potential remap.
Old-Git
Post
by Old-Git » Fri Apr 24, 2020 10:17 am
Fitted it yesterday.... it's about 3/4 of an inch too long. Will fit OK with std silencer but not with the Akra, which has an internal lip. Just debating which bit to modify, the downpipes or the collector.... or should I send it back.....
Post
by David. » Fri Apr 24, 2020 11:42 am
I suppose the BW headers have to be manufactured to fit with an OEM silencer or one of their own.
I guess if you are likely to sell the bike in the future, the OEM headers & silencer could be refitted.
Chop it & fit the Akra.
David. on Fri Apr 24, 2020 11:45 am, edited 1 time in total.
Old-Git
Post
by Old-Git » Sat Apr 25, 2020 10:02 am
Yep that's what I did. BTW the new system is 3.7 kilos, old one (incl servo motor etc) is 4.3 kilos. So not the huge weight reduction I was hoping for.
Post
by David. » Sat Apr 25, 2020 10:10 am
David. wrote: Look forward to hearing how you get on with your local bike dealer and any potential remap.
