Oil Filter...?
- Been liked: 334 times
Re: Oil Filter...?
The Hiflo 160 is correct, the BMW Original is incorrect,
it's for a pre-LC, the label looks odd, should be 11427721779.
Just noticed the label has Nippy Normans on it,
https://www.nippynormans.com/spares-for ... 250gsrrsrt
Re: Oil Filter...?
Have a look closely at the photos in this NN link for a pre-LC oil filter, they show both.Old-Git wrote:I'll get Nippy Normans to send the correct one.
https://www.nippynormans.com/k1200gt-06 ... k1600gtgtl
Could use the Hiflo one, I supply and BMW fit them to my Camhead.
Have it in writing from BMW Insured Warranty that it is perfectly acceptable to use Hiflo filters.
Or, get a Mahle one, they make them for BMW.
Re: Oil Filter...?
Yep I'm happy to use the HiFlo one, I've used them on many bikes over the years. I wouldn't use an unbranded one, but these are OK.
Re: Oil Filter...?
BMWIW agree that both Hiflo & Mahle filters are, "considered to be of equivalent quality to an OEM filter, and have no issues using them as part of routine servicing".Old-Git wrote:Yep I'm happy to use the HiFlo one.
Re: Oil Filter...?
Bmw said I could use a space saver with my X1 but I had to return it as it was not compatible with M Sport brakes. Their system was wrong.
Re: Oil Filter...?
Found this on BMW X1/X2, https://f48.bimmerpost.com/forums/showt ... 685&page=4
BMW UK confirmed that a space saver is not an option on an X1 with M Sport brakes due to storage space. Was it just a local BMW dealer parts dept. error.
It happens, just like NN got the wrong oil filter, https://www.nippynormans.com/about
Re: Oil Filter...?
Storage is not the issue as there is a double boot. The problem is MSort calipers run too near the wheel rim and will foul the spacesaver. They've got it wrong again.
Re: Oil Filter...?
Sorry, my mistake.
Posted on BMW X1/X2, "Just to say that a Space saver is not an option with M Sport Brakes".
There appears to be a space saver available but for some reason, not to retail customers.
Not sure what this has got to do with an oil filter, other than to show that errors can be and are made when ordering parts.
Re: Oil Filter...?
"I found this on another website.
[size=1.125em]These Oil Filters[size=4px][/size][size=4px][size=4px]have 3/4"-16 threads,[/size][size=4px][size=4px]by-pass valve,[/size][size=4px][size=4px]no anti-drain back valve.[/size][size=4px][size=4px][size=4px]BMW motorcycles with spin on filters use three different filters. The only difference I can see is the height of the filter - it's either 65mm, 71mm or 90m. If you have room on your bike for the 90mm filters (listed below), use those.[/size][size=4px][size=4px][size=4px]The 65mm filters are made to a very old spec with inferior filtering and should be avoided. Use one of the 71mm or 90mm filters instead."[/size]
[size=4px]
[/size]
[size=4px]If you would like to see the website it's here [/size][size=78%]http://www.calsci.com/motorcycleinfo/FilterXRef.html[/size]
This site was last updated on 3/9/17.
[size=4px]
[/size]
The cheapest thing on a BMW is the nut that connects the handlebars to the seat.
Re: Oil Filter...?
The info. from the CalSci website doesn't look correct for an R1200RT.
Using the Hiflo catalogue, http://www.hiflofiltro.com/catalogue
The Hiflo catalogue also gives a cross-reference to the BMW part numbers.
The HF160 for an LC is 62mm, not 65mm.
OK, only a small difference but wait.
The HF164 for a pre-LC is 54mm, not 71mm.
The HF163 is 79mm, not 90mm.
This photo shows a HF160 at 62mm which is larger than HF164 at 54mm (same as the BMW one for pre-LC's)
Whilst I'm very happy to supply and have fitted a Hiflo filter, I'd rather it be the correct one.
Re: Oil Filter...?
The most important thing that I got from the CalSci website is that they all have the same threads, no-anti drain back valve, and a bypass valve. With all that being the same I would think that a longer filter would have a higher capacity for filtering regardless of brand. I have given some thought into using the same filter that I use on my 91 K-bike on the 18 R1200RT. The first time I saw the filter on my 18 R1200RT I thought "good grief, why such a short filter when there is plenty of room for a longer one".
Re: Oil Filter...?
Don't think I'd be too comfortable fitting a larger than spec. oil filter. Without an anti-drainback valve, oil pressure may take longer to build up. What impact would it have on oil pressure. If I was concerned about oil filtering, I'd rather change the oil & filter more frequently than recommended.
