Differential Rear Spline Lubrication Interval
Been liked: 337 times
Re: Differential Rear Spline Lubrication Interval
"The cardan shaft is a secondary drive between manual gearbox and rear wheel and is distinguished by its extremely long service life and consistently high performance.
This removes the need for time-consuming maintenance work."
"The bore hole in the axle pipe also ensures effective heat discharge out of the rear axle housing."
BMW Warranty will not cover: repair or replacement required wholly or partially due to lack of maintenance.
There is no BMW service (maintenance) recommendation for the driveshaft.
I'd rather leave things alone and not give them an excuse not to pay out should the driveshaft fail because I've buggered about with it.
Beagle
Post by Beagle »
How long is your warranty?
Each year, I have a monthly "pay as you go" warranty between April & October inc.
There is an option available to be able to renew it up to when the bike has done 80,000 miles.
Beagle
Post by Beagle »
Who is that with if you don't mind me asking.
BMW Motorrad Insured Warranty, https://www.motorrad-warranty.co.uk/Login/Index
Paid £35 in March for commencement in April. Cancelled it and got my money back. Have the option to renew again later in the year.
Beagle
Post by Beagle »
Thanks.
How about this for a theory. Does this photo suggest that any "sliding" takes place between the different diameters of the driveshaft, within the cushion drive.
BMW call it, "a torsional vibration damper is integrated into the cardan shaft for greater comfort".
Here's a thread from R1200GS.info, https://www.r1200gs.info/threads/final- ... sue.48429/ scroll down to reply #16, looks very similar to the above.
(Left click on photos to enlarge).
Tube-in-Tube Torsional Isolators, https://www.vibracoustic.com/en/product ... isolators/
Beagle
Post by Beagle »
This removes the need for time-consuming maintenance work”
Yeah right and the moon’s made of green cheese, the earth’s flat and David Ike talks sense.
Just as well one David talks sense!
It appears that if the rear UJ to FD unit splines are badly seized together, there may be a risk of front UJ to gearbox output shaft becoming disconnected when dropping the FD unit.
This is exactly what happened in this video, https://www.youtube.com/watch?v=c1_1gPR ... u.be&t=946 see around 19:15.
