Does anyone know what this missing fastener maybe?
Wonder if someone can help here? I have a 2014 R1200RT... on the left , front side, when I remove the fairing panel i can see an air intake above the radiator, there is some sort of fastner that is missing from that spot that attaches the air intake to the body, it is not a regular screw as best as i can tell. .... I've attached 2 photos pointing to the spot. I've pulled my hair out trying to look at different parts fiches but can't seem to find it. anyone have any idea from the photos what this may be? thanks in advance, Ira
2014 BMW R1200RT
Re: Does anyone know what this missing fastener maybe?
Try this
- Been liked: 334 times
Thank you!... Not very clear ... but now i understand. thank you! Ira
2014 BMW R1200RT
- Sprintgull
Hi Ira
Just had that side apart on my 2016 to fit some Denali lights. The bracket uses the two screws you can see behind the air duct, so I removed the screw that you have missing while the bracket was fitted.. From memory it was a black Torx head screw. I don't think it is the end of the world if it is missing, just leaves a small air gap.
ichavis wrote: Thank you!... Not very clear ... but now i understand. thank you! Ira
You could buy a mushroom head stainless 5x12 mm screw and add a washer or you could get one from the dealer.
Flanged button head screws are available without going to a BMW dealer.
...................... Or you could have a look in your bolt/screw box In the garage and you may have one or a longer one you can cut down.
I do have one similar, maybe 20
2014 BMW R1200RT
David. wrote:3 Fillister head screw (07147305240)
I wish BMW would ditch that unhelpful description (Fillister head). It really doesn't tell the end user much at all.
Fastener names are known by those who install them regularly. Aircraft owners dont always know about Jo Bolts and Hi-Loks
Now we know what Fillister Heads are.. Every day’s a school day.
Beagle wrote: Fastener names are known by those who install them regularly. Aircraft owners dont always know about Jo Bolts and Hi-Loks
But we don't, because fillister head screws in theory are like slotted domed cheesehead machine screws. However, BMW calls a variety of their bolts 'Fillister head' including some Torx head, Hexhead socket cap bolts, domed head trim screws etc. It is most unhelpful.
Here are a some examples:
[size=11px]54 10 7 055 524 FILLISTER HEAD SCREW - 4X15[/size]
[size=11px][align=center]11[/align] 07 11 9 910 374 FILLISTER-HEAD SCREW - M8X25[/size]
[size=11px][align=center]03[/align] 07 11 9 907 779 FILLISTER HEAD SELF-TAPPING SCREW - ST5,5X19[/size]
[size=11px][align=center]04[/align] 46 63 2 313 246 FILLISTER-HEAD SCREW - M8X25[/size]
[size=11px][align=center]09[/align] 46 62 2 307 956 FILLISTER HEAD SCREW - M5X16 A4/80 SW[/size]
