Start up Issue
matgriff
Start up Issue
Post by matgriff »
Hi, I've noticed an intermittent problem with my 2005 1200RT  Probably happens about 1 in 20 start cycles.
I turn the key to the on position, and the yellow triangle appears with the EWS display on the dash. The bike won't turn over, if I switch off/on again it usually clears it. It's only on startup and never gives a problem once started.
I read that it could be a problem with the RFID antenna that reads the key chip ?  Is this likely to get worse and leave me stranded ?  Is it an easy repair ?
Thx
Mat
Been liked: 345 times
Re: Start up Issue
A "Google" search has come up with a technical campaign (recall) on some EWS rings.
Here is a list of VIN nos., (not sure if they are just US models),  https://www.bmwlt.com/forums/rt-series/ ... -info.html
Further info. from BMWMOA, https://forums.bmwmoa.org/showthread.ph ... t-EWS-quot
More from Adventure Rider, check the part no. ends in 247, https://advrider.com/f/threads/replace- ... ng.620400/
Emergency ring antenna replacement, https://www.youtube.com/watch?v=kQnGgAOzcng
A new ring antenna #6 is £33.82, https://www.online-parts.co.uk/bmw-bike ... nth=01#sub
Re: Start up Issue
Looks like the ignition switch may need to be removed to replace the ring antenna.
How to remove the ignition switch, https://advrider.com/f/threads/how-to-r ... h.1207286/
Re: Start up Issue
matgriff wrote:Is this likely to get worse and leave me stranded?
Looks like it could be a possibility. Carrying a spare ring antenna and key might just save the day.
matgriff wrote:Is it an easy repair?
Looks like a right chew on removing the ignition switch. https://www.youtube.com/watch?v=CltWWNdropk
matgriff
Re: Start up Issue
Post by matgriff »
Thanks for the info, I'll have a read up on it :-)
Mat
matgriff
Re: Start up Issue
Post by matgriff »
As a test I decided to remove my topbox key off the main bike keyring to see if that helped..... went out on the bike yesterday and no re-occurrence of the EWS message, so maybe the topbox key was affecting the antenna ?  Time will tell.
Re: Start up Issue
Thanks for the feedback, problem solved.
The Rider's Manual states, "A spare key attached to the same ring as the ignition key used to start the engine could "irritate" the electronics, in which case the enabling signal for starting is not issued. The EWS warning appears in the multifunction display. Always keep the spare key separate from the ignition key."
Sprintgull
Re: Start up Issue
Post by Sprintgull »
On long trips I have the spare key on a landyard around my neck.  Never had a problem so that must be out of range.
